How do you find out the fix for a TSB? I have seen
Old Jan 22, 2002 | 07:38 PM
The New CLIMAX's Avatar
links to the actual info that the mechanics are to use or follow for a TSB, but how do you find out this info for a specific TSB? Thanks
Old Jan 22, 2002 | 07:47 PM
in case you guys know how to ...
this is the TSB
Service Bulletin Number: NTB00070A
Old Jan 22, 2002 | 11:28 PM
sleepermax's Avatar
Hey Adam - check out this link:
http://www.alldata.com/TSB/41/00416289.html
Your TSB is #10 on the list ( 00-070 AUG 00 Engine Control Module - MIL ON, DTC P0420 Set). They offer a year's subscription for $24.95. I don't know where you can get the complete TSB's for free though....
Old Jan 22, 2002 | 11:47 PM
Mr. Green's Avatar
TSB List
I have a saved list in a word doc.
I don't know if this list will copy over right but I'll give it a shot.
17 pages of 2K Max TSB's. Warning, Very Long.
Make: NISSAN Model: MAXIMA Year: 2000
Service Bulletin Number: NTB00008 Bulletin Sequence Number: 995 Date of Bulletin: 01/00
NHTSA Item Number: SB609977
Component: FUEL:FUEL INJECTION:IDLE SPEED CONTROL UNIT
Summary: SOME VEHICLES MAY EXHIBIT LOW / NO IDLE WHEN SHIFTING INTO D OR R RANGE AFTER COLD START. *TT
Service Bulletin Number: NTB00008A Bulletin Sequence Number: 109 Date of Bulletin: 03/00
NHTSA Item Number: SB610995
Component: ENGINE
Summary: SOME VEHICLE WITH VARIOUS VIN RANGES MAY EXHIBIT LOW / NO IDLE WHEN SHIFTING INTO D OR R RANGE AFTER COLD START. *TT
Service Bulletin Number: NTB00016 Bulletin Sequence Number: 109 Date of Bulletin: 02/00
NHTSA Item Number: SB610984
Component: BRAKES:HYDRAULIC SYSTEM
Summary: SOME VEHICLES MAY DEMONSTRATE A LOUD, LOW FREQUENCY GROAN NOISE COMING FROM THE FRONT BRAKES DURING STOPPING. *TT
Service Bulletin Number: NTB00030 Bulletin Sequence Number: 109 Date of Bulletin: 03/00
NHTSA Item Number: SB610991
Component: SUSPENSION:INDEPENDENT FRONT ATTACHING MECHANISMS:STRUT ROD
Summary: THIS BULLETIN CONTAINS REPAIR PROCEDURES FOR VEHICLES EXHIBITING A CLICK OR CLUNK NOISE FROM THE RIGHT FRONT STRUT. *TT
Service Bulletin Number: NTB00030A Bulletin Sequence Number: 139 Date of Bulletin: 06/00
NHTSA Item Number: SB613978
Summary: SERVICE INFORMATION REGRDING RIGHT FRONT STRUT NOISES. *TT
Service Bulletin Number: NTB00032 Bulletin Sequence Number: 134 Date of Bulletin: 05/00
NHTSA Item Number: SB613469
Component: ELECTRICAL SYSTEM:WIRING:HARNESS:FRONT:UNDERHOOD
Summary: SOME VEHCILES REQUIRE THAT AN ADAPTER HARNESS BE USED TO CONNECT SRS MODULES OR SEAT BELT PRE-TENSIONERS TO THE DEPLOYMENT TOOL. *TT
Service Bulletin Number: NTB00039 Bulletin Sequence Number: 134 Date of Bulletin: 05/00
NHTSA Item Number: SB613483
Component: STEERING:GEAR BOX
Summary: EXHIBITING SLOW OR DELAYED SHIFTING FROM FIRST TO SECOND GEAR (PARTICULARLY AT ONE-HALF OR GREATER THROTTLE APPLICATION). *TT
Service Bulletin Number: NTB00039A Bulletin Sequence Number: 158 Date of Bulletin: 12/00
NHTSA Item Number: SB615859
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC
Summary: SOME VEHICLES MAY EXHIBIT SLOW OR DELAYED SHIFTING FROM FIRST TO SECOND GEAR OR FROM SECOND TO THIRD GEAR (PARTICULARLY AT ONE-HALF THROTTLE OR GREATER APPLICATION). *TT
Service Bulletin Number: NTB00039B Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB620000
Summary: SOME VEHICLES MAY EXHIBIT DELAYED SHIFTING FROM FIRST TO SECOND GEAR OR FROM SECOND TO THIRD GEAR (PARTICULARLY AT ONE-HALF THROTTLE OR GREATER APPLICATION). *TT
Service Bulletin Number: NTB00039D Bulletin Sequence Number: 625 Date of Bulletin: 09/01
NHTSA Item Number: SB625508
Summary: SOME VEHICLES MAY EXHIBIT SLOW OR DELAYED SHIFTING FROM FIRST TO SECOND GEAR OR FROM SECOND TO THIRD GEAR. *TT
Service Bulletin Number: NTB00041 Bulletin Sequence Number: 126 Date of Bulletin: 05/00
NHTSA Item Number: SB612640
Summary: SOME VEHICLES MAY EXHIBIT A DIAGNOSTIC TROUBLE CODE P0505 AAC/V STORED, WITH NO CUSTOMER DRIVEABILITY INCIDENT, DUE TO INCORRECT ENGINE IDLE SPEED SETTING. *TT
Service Bulletin Number: NTB00042 Bulletin Sequence Number: 134 Date of Bulletin: 05/00
NHTSA Item Number: SB613475
Component: INTERIOR SYSTEMS:PASSIVE RESTRAINT:AIR BAG
Summary: SUBJECT REGARDING MODIFICATIONS TO AND / OR TAMPERING WITH THE SUPPLEMENTAL SIDE AIR BAG SYSTEM. *TT
Service Bulletin Number: NTB00052 Bulletin Sequence Number: 139 Date of Bulletin: 07/00
NHTSA Item Number: SB613967
Summary: SUBJECT REGARDING ECM REPLACEMENT PROCEDURES FOR VEHICLES WITH REPROGRAMMABLE ECMS. *TT
Service Bulletin Number: NTB00055 Bulletin Sequence Number: 139 Date of Bulletin: 07/00
NHTSA Item Number: SB613954
Component: STRUCTURE:BUMPER ASSEMBLY
Summary: VEHICLES BUILT BEFORE JN1CA31D1YT766295, JN1CA31A6YT224079, JN1CA31D5YT555214, JN1CA31A3YT031422 MAY HAVE A SCRATCH(S) IN THE TOP OF THE REAR BUMPER JUST BELOW THE LOWER EDGE OF THE TRUNK LID. *TT
Service Bulletin Number: NTB00070A Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB619999
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary: SOME VEHICLES MAY EXHIBIT A MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0420 (THREE WAY CATALYST FUNCTION) STORED IN THE ECM. *TT
Service Bulletin Number: NTB00077 Bulletin Sequence Number: 148 Date of Bulletin: 09/00
NHTSA Item Number: SB614900
Component: FUEL:FUEL SYSTEMS
Summary: SUBJECT REGARDING ESSENTIAL TOOL - FUEL PRESSURE GAUGE KIT. *TT
Service Bulletin Number: NTB00088 Bulletin Sequence Number: 187 Date of Bulletin: 10/00
NHTSA Item Number: SB618790
Summary: SOME VEHICLES MAY EXHIBIT STEERING WHEEL / BODY VIBRATION OR BRAKE PEDAL PULSATION WHEN BRAKING (ESPECIALLY DURING HIGH SPEED BRAKING),AND / OR BRAKE JUDDER. *TT
Service Bulletin Number: NTB00090 Bulletin Sequence Number: 187 Date of Bulletin: 11/00
NHTSA Item Number: SB618788
Component: STRUCTURE:TRUNK LID AND DOOR ASSEMBLY:HINGE AND ATTACHMENTS
Summary: ON SOME VEHICLES, THE TRUNK ROOM SIDE FINISHER MAY POP OUT OF PLACE. *TT
Service Bulletin Number: NTB01010 Bulletin Sequence Number: 187 Date of Bulletin: 02/01
NHTSA Item Number: SB618795
Component: ENGINE
Summary: SOME VEHICLES MAY EXHIBIT A BUZZING NOISE COMING FROM THE ENGINE COMPARTMENT FOR SEVERAL SECONDS AFTER THE IGNITION KEY IS TURNED OFF. *TT
Service Bulletin Number: NTB01016B Bulletin Sequence Number: 624 Date of Bulletin: 09/01
NHTSA Item Number: SB624059
Summary: INFORMATION ON MIL WITH REAR 02 SENSOR DTC.*JB
Service Bulletin Number: NTB01018A Bulletin Sequence Number: 625 Date of Bulletin: 10/01
NHTSA Item Number: SB625926
Component: FUEL:THROTTLE LINKAGES AND CONTROL
Summary: SUBJECT REGARDING ON/OFF THROTTLE SENSITIVITY. *JG
Service Bulletin Number: NTB01029 Bulletin Sequence Number: 625 Date of Bulletin: 05/01
NHTSA Item Number: SB625091
Component: STRUCTURE:DOOR ASSEMBLY:FRAME AND PANEL
Summary: SUBJECT REGARDING WIND NOISE REAR GLASS RUN RUBBER.
NHTSA Item Number: SB625307
Component: VISUAL SYSTEMS:GLASS
Summary: INFORMATION ON WIND NOISE REAR GLASS RUN RUBBER.*YD
Service Bulletin Number: NTB01036 Bulletin Sequence Number: 624 Date of Bulletin: 09/01
NHTSA Item Number: SB624041
Component: EXHAUST SYSTEM:MANIFOLD:OXYGEN SENSOR
Summary: INFORMATION REGARDING MIL ON DTC MASSAIRFLOW SENSOR, MAFS.*JB
Service Bulletin Number: NTB01036 Bulletin Sequence Number: 625 Date of Bulletin: 05/01
NHTSA Item Number: SB625190
Component: AIR CONDITIONER
Summary: SUBJECT REGARDING MIL ON WITH DTC P01000 (MASS AIRFLOW SENSOR-MAFS)STORED. *YD
Service Bulletin Number: NTB01037 Bulletin Sequence Number: 625 Date of Bulletin: 05/01
NHTSA Item Number: SB625197
Component: VISUAL SYSTEMS:GLASS:POWER WINDOW DOOR AND SIDE
Summary: SUBJECT REGARDING DRIVER'S FRONT POWER WINDOW - NO OPERATION. *YD
Service Bulletin Number: NTB01042 Bulletin Sequence Number: 625 Date of Bulletin: 05/01
NHTSA Item Number: SB625212
Summary: SUBJECT REGARDING WINDOW REGULATOR POP/TICK NOISE. *YD
Tim
Old Jan 22, 2002 | 11:50 PM
Mr. Green's Avatar
part 2
Continued,
would not fit in 1 post.
Service Bulletin Number: NTB01051 Bulletin Sequence Number: 621 Date of Bulletin: 08/01
NHTSA Item Number: SB621976
Summary: SOME VEHICLES MAY EXPERIENCE A RATTLE OR BUZZ NOISE COMING FROM THE REAR PARCEL SHELF BOARD WHEN LISTENING TO LOW FREQUENCY / HIGH BASS AUDIO. *TT
Service Bulletin Number: NTB01051A Bulletin Sequence Number: 625 Date of Bulletin: 10/01
NHTSA Item Number: SB625930
Summary: SUBJECT REGARDING BOSE AUDIO; REAR PARCEL SHELF RATTLE/BUZZ NOISE. *JG
Service Bulletin Number: NTB01054 Bulletin Sequence Number: 624 Date of Bulletin: 08/01
NHTSA Item Number: SB624007
Component: VISUAL SYSTEMS:GLASS:WINDOW:DOOR AND SIDE
Summary: INFORMATION ON FRONT GLASS RUN RUBBER SQUEAK NOISE.*JB
Service Bulletin Number: NTB01059 Bulletin Sequence Number: 623 Date of Bulletin: 09/01
NHTSA Item Number: SB623993
Summary: INFORMATION REGARDING MIL ON WITH DTC AND OR SPARK KNOCK DUE TO IGNITION COIL.*JB
Service Bulletin Number: NTB01065 Bulletin Sequence Number: 624 Date of Bulletin: 09/01
NHTSA Item Number: SB624001
Component: VISUAL SYSTEMS:MIRRORS:REARVIEW:EXTERIOR
Summary: VEHICLES MAY EXPERIENCE DOOR MIRROR VIBRATION.*JB
Service Bulletin Number: NTB01071 Bulletin Sequence Number: 625 Date of Bulletin: 10/01
NHTSA Item Number: SB625922
Component: INTERIOR SYSTEMS:SEAT TRACK ANCHORS AND SEATS
Summary: SUBJECT REGARDING DRIVER'S SEAT MOVING FROM SIDE TO SIDE. *JG
Service Bulletin Number: NTB01076 Bulletin Sequence Number: 625 Date of Bulletin: 11/01
NHTSA Item Number: SB625932
Summary: SUBJECT REGARDING EGI HARNESS, WIRE BREAKAGE. *JG
Service Bulletin Number: NTB99017A Bulletin Sequence Number: 109 Date of Bulletin: 02/00
NHTSA Item Number: SB610985
Component: ENGINE COOLING SYSTEM
Summary: SOME CUSTOMERS MAY INDICATE THAT A LIGHT TICKING OR HUMMING NOISE CAN BE HEARD COMING FROM THE BLOWER MOTOR OF AN APPLIED VEHICLE WHEN THE MOTOR IS RUN AT LOW FAN SPEEDS. *TT
Service Bulletin Number: NTB99038 Bulletin Sequence Number: 620 Date of Bulletin: 06/99
NHTSA Item Number: SB606199
Component: STRUCTURE:DOOR ASSEMBLY:HANDLE:OUTSIDE
Summary: INFORMATION REGARDING THE PAINT PROTECTION DOOR HANDLE AREA AND EDGE. *TT
Service Bulletin Number: NTB99045 Bulletin Sequence Number: 672 Date of Bulletin: 06/99
NHTSA Item Number: SB606721
Summary: THIS BULLETIN PROVIDES HELPFUL TIPS FOR REMOVAL AND REPLACEMENT OF INTERIOR TRIM ON CERTAIN VEHICLES. *TT
Service Bulletin Number: NTB99046 Bulletin Sequence Number: 812 Date of Bulletin: 07/99
NHTSA Item Number: SB608136
Summary: OWNERS OF VEHICLES BUILT PRIOR TO THE APPLIED VINS MAY COMMENT THAT THE OUTER EDGE OF THE DOOR FINISHER CLOTH INSERTS ON ANY OF THE DOORS APPEAR ROUGH OR UNEVEN, OR NOT FULLY INSERTED INTO THE DOOR FINISHER. *TT
Service Bulletin Number: NTB99046A Bulletin Sequence Number: 995 Date of Bulletin: 01/00
NHTSA Item Number: SB609979
Summary: CUSTOMERS MAY COMPLAIN THAT THE OUTER EDGE OF THE DOOR FINISHER CLOTH INSERTS ON ANY OF THE DOORS APPEAR ROUGH OR UNEVEN, OR IS NOT FULLY INSERTED INTO THE DOOR FINISHER. *TT
Service Bulletin Number: NTB99055A Bulletin Sequence Number: 139 Date of Bulletin: 02/00
NHTSA Item Number: SB613957
Component: STRUCTURE:BODY ROOF
Summary: CONCERNS WITH THE HEADLINER SAGGING AT THE SUNROOF RAILING ON VEHICLES BUILT BEFORE JN1CA31A4YT010384, JN1CA31A8YT209437, JN1CA31D0YT524517, JN1CA31D2YT7334418. *TT
Service Bulletin Number: NTB99056 Bulletin Sequence Number: 994 Date of Bulletin: 09/99
NHTSA Item Number: SB609966
Summary: INFORMATION USED TO IDENTIFY AND ISOLATE SQUEAK AND RATTLE NOISE(S) ON SOME VEHICLES. *TT
Service Bulletin Number: NTB99056A Bulletin Sequence Number: 994 Date of Bulletin: 11/99
NHTSA Item Number: SB609963
Summary: SUPPLEMENTAL INFORMATION FOR VEHICLES EXHIBITING SQUEAK AND RATTLE NOISE(S). *TT
Service Bulletin Number: NTB99056E Bulletin Sequence Number: 166 Date of Bulletin: 02/01
NHTSA Item Number: SB616639
Summary: SUBJECT REGARDING INTERIOR SQUEAK AND RATTLE REPAIR. *TT
Service Bulletin Number: NTB99063 Bulletin Sequence Number: 804 Date of Bulletin: 09/99
NHTSA Item Number: SB608050
Component: ELECTRICAL SYSTEM:IGNITION ANTI-THEFT CONTROLLER
Summary: ON SOME VEHICLES, THE NISSAN VEHICLES IMMOBILIZER SYSTEM / NISSAN ANTI-THEFT SYSTEM (NVIS / NATS) WILL NOW ALLOW THE ENGINE TO START WITHOUT THE USE OF A REGISTERED IGNITION KEY. *TT
Service Bulletin Number: NTB99063A Bulletin Sequence Number: 109 Date of Bulletin: 02/00
NHTSA Item Number: SB610982
Component: ELECTRICAL SYSTEM:IGNITION:ANTI-THEFT
Summary: THIS BULLETIN DESCRIBES AND INTRODUCES NEW FEATURES OF THE NISSAN VEHICLE IMMOBILIZER SYSTEM / NISSAN ANTI-THEFT SYSTEM (NVIS / NATS). *TT
Service Bulletin Number: NTB99063B Bulletin Sequence Number: 139 Date of Bulletin: 08/00
NHTSA Item Number: SB613972
Summary: A CONDITION MAY EXIST WHERE THE NISSAN VEHICLE IMMOBILIZER SYSTEM / NISSAN ANTI-THEFT SYSTEM WILL NOT ALLOW THE ENGINE TO START WITHOUT THE USE OF A REGISTERED IGNITION KEY. *TT
Service Bulletin Number: NTB99077 Bulletin Sequence Number: 994 Date of Bulletin: 11/99
NHTSA Item Number: SB609962
Component: AIR CONDITIONER:REFRIGERANT
Summary: INFORMATION INTRODUCING THE FACTORY-INSTALLED R-134A AIR CONDITIONER SYSTEM REFRIGERANT DYE. *TT
Service Bulletin Number: NTB99077B Bulletin Sequence Number: 187 Date of Bulletin: 10/00
NHTSA Item Number: SB618801
Summary: INFORMATION REGARDING INTRODUCTION OF FACTORY-INSTALLED R-134A A/C SYSTEM REFRIGERANT DYE. *TT
Service Bulletin Number: NTB99078 Bulletin Sequence Number: 995 Date of Bulletin: 10/99
NHTSA Item Number: SB609974
Summary: A CONDITION MAY EXIST WITH THE TCS AND SLIP INDICATOR LIGHTS ON VEHICLES EQUIPPED WITH TRACTION CONTROL SYSTEM (TCS). *TT
Service Bulletin Number: NTB99078A Bulletin Sequence Number: 995 Date of Bulletin: 01/00
NHTSA Item Number: SB609980
Summary: SOME VEHICLES EQUIPPED WITH TRACTION CONTROL SYSTEM (TCS) MAY EXHIBIT TCS AND SLIP INDICATOR LIGHTS ON DURING NORMAL DRIVING CONDITIONS. *TT
Tim
Old Jan 23, 2002 | 07:28 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Wow, did you copy and paste all the TSB's from the NHTSA site?
Old Jan 23, 2002 | 12:43 PM
I have that info but I wanna know the fix for the TSB? Where do we get that?
Old Jan 24, 2002 | 01:32 AM
Mr. Green's Avatar
Kev- Yea thats ever one of them. at least for a 2K.
Climax- The part # of the TSB is listed. All you have to do is either call NHTSA and have them mail or fax you a copy or fill out a web request form to get them to send the full detailed TSB. If you do this via Web there is a fee you have to pay to get it. If you call sometimes the will ask for a fee too but, on occasion you can get them to fax it to you for free.
Old Jan 24, 2002 | 04:22 AM
jnm2kse's Avatar
Does anyone have the full TSB for
If you have a manual drivers seat I can guarantee that you have this problem.....the dealer tried fixing this once for me. It came back and is real annoying every corner you take with your seat going click, clank, clunk.
Old Jan 24, 2002 | 06:17 AM
DAVEB's Avatar
Kevin just added that one to the TSB sticky the other day- My car does that too!
Old Jan 24, 2002 | 06:58 AM
Y2KevSE's Avatar
Old Jan 24, 2002 | 11:28 AM
jnm2kse's Avatar
Originally posted by Y2KevSE
Thanks Kev!!
I've been waiting for a fix for this annoying condition for a long time!
Now comes the fun part..actually convincing the dealer that this TSB applys
lol
Thanks again!
Old Feb 27, 2002 | 07:17 PM
Minh's Avatar
Fan Noise TSB
I have the same problem, just found this TSB, going to give the dealer a shout / shot tomorrow.
Blower Motor - Noise
Classification:
HA99-004A
Reference:
NTB99-071A
Date:
February 10, 2000
NISSAN BLOWER MOTOR NOISE - COVER INSTALLATION
This amended version of NTB99-071 updates the services and Claims Information Sections. Please discard all paper copies of NTB99-071.
APPLIED VEHICLES:
1996-1999 Pathfinder (R50)
1995-1999 Maxima (A32)
2000 Maxima (A33) with Automatic Heater/Air Conditioner Controls
SERVICE INFORMATION:If a customer indicates that a light ticking or humming noise can be heard coming from the blower motor of an applied vehicle when the motor is run at low fan speeds (speed 1 or 2), a new, noise reducing blower motor cover is available (see Figure 1). The noise, if it occurs, may be very slight and, at times, difficult to hear.
Use the Service Procedure in this bulletin to evaluate the noise and determine the next step to correct the condition.
NOTE: This is the ONLY approved repair procedure for this incident. A claim to Nissan for the repair of this incident may be denied if the repair is not performed exactly as outlined in this bulletin.
SERVICE PROCEDURE:
Run the blower motor at low fan speed (speed 1 or 2) and evaluate the noise, if any. Decide which of the two following categories the noise falls under:
1. Loud rattle, clatter, jolt, or flap: Go to the procedure for Blower Case Cleaning.
2. Light ticking or humming noise: Complete the steps below to Install Blower Motor Cover.
Install Blower Motor Cover:
NOTE: It is not necessary to remove the blower motor when installing the blower motor cover.
1. Remove the instrument panel lower cover (if equipped).
2. Disconnect the blower motor harness connector.
3. Clean the blower motor housing to ensure adhesive strips on the back of the blower motor cover will stick (standard window cleaner or other all-purpose cleaner can be used).
NOTE: Be sure to remove all residual film from the blower motor housing that may have been left by cleaning.
4. Peel the protective coverings from the adhesive strips on the blower motor cover (see Figure 1 for adhesive strip locations).
5. Install the blower motor cover onto the motor bracket (see Figure 2).
6. Re-connect the blower motor harness connector.
7. Re-attach the instrument panel lower cover (if equipped).
8. Run the blower motor at low fan speed. Confirm that the blower motor is working properly and the noise is eliminated or reduced to an acceptable level.
Blower Case Cleaning: 1. Remove blower motor unit from the blower case.
2. Remove all foreign material from the case.
3. Re-install the blower motor unit.
4. Run the blower motor at low fan speed (speed 1 or 2) and re-evaluate the noise:
A. If the noise is gone, no further action is needed.
B. If the noise is still a loud rattle, clatter, jolt, or flap, investigate other causes for the noise and repair as needed.
C. If the noise is a light ticking or humming, go to and complete the Install Blower Motor Cover procedure.
PARTS INFORMATION
DESCRIPTION PART # /PFP QUANTITY
Blower Motor Cover 27227-0E002 1
CLAIMS INFORMATION
Old Feb 27, 2002 | 10:19 PM
K Pazzo 6's Avatar
Old Feb 28, 2002 | 07:47 AM
theMax's Avatar
NTB00039D!
That auto tranny TSB is up to D now! Thats 4 revisions.
Does anyone know if the TCM and solinoid is still the fix?
Old Mar 1, 2002 | 09:49 PM
MarkG's Avatar
I subscribe to AllData for TSB's and all the info pictures instructions etc are given it costs $25 for one year for one car. I subscribed for my 2K Max. I dont mind sharing info with org members...just dont overwhelm me with requests for info
Old Mar 2, 2002 | 07:28 AM
theMax's Avatar
Is it electronic format? If it is or you can scan it, I can put it on my website for everyone to use.
Thanks!
9aj9
Apr 5, 2020 12:11 AM
