Need help
Old Sep 14, 2014 | 08:32 PM
2kmax865's Avatar
Need help
I had the harmonic balancer separate and took out belts. Replaced everything and now when I start it, it turns over quite a few times before it starts. Wondering if crank sensor is damaged or it jumped time?
Old Sep 14, 2014 | 09:43 PM
tosheto's Avatar
Look at the sensor and its wiring. See if there is any visible damage. I had a Maxima that had damage in the harness of the sensor and the car had hard time starting.
Old Sep 14, 2014 | 10:33 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, considering that the crank sensor is close to the crank pulley, there's no doubt probably some damage from **** flying everywhere
I just replace those POS with UDPs. Cheaper, problem solved for life, plus a little power is freed.
Old Sep 15, 2014 | 06:39 PM
2kmax865's Avatar
Thanks for the input. Didn't think about UDP already installed replacement. Did check and found damage to sensor will replace it.
Old Sep 17, 2014 | 11:05 AM
NmexMAX's Avatar
dot dot dot ...
For next time ... https://maxima.org/forums/4th-genera...e-contest.html
Old Sep 18, 2014 | 10:34 AM
CMax03's Avatar
replace sensor with a junk yard unit as a test....But I'm sure it's damage or bent too far away!
