Seized jam nut
Old Sep 25, 2014 | 10:00 AM
2damax's Avatar
Seized jam nut
Hey guys, I have a small issue. I replace my outer tie rods a couple weeks ago. I noticed the driver side jam nut is seized to the inner tie rod. I just replace my tires and I cannot get an alignment on that wheel since the nut won't spin.
I tried tons of PB and a benzomatic. Any other ideas?
Thanks in advance.
Old Sep 25, 2014 | 11:42 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
dremel the nut out, heat, or replace the inner and out again
Old Sep 26, 2014 | 05:12 AM
2damax's Avatar
Is the heat from the benzomatic enough heat? The other options you listed are more of a last resort for me.
Old Sep 28, 2014 | 06:16 AM
Max_Gator's Avatar
If you can get the outer tie rod off, you should be able to get a nut splitter onto that nut. Can find them at sears or auto parts stores.
Old Sep 28, 2014 | 09:48 AM
2damax's Avatar
^ thanks. That is what I am doing my next day off.
Old Sep 28, 2014 | 09:56 AM
CMax03's Avatar
If you get it off The threads wiil be so messed up you'll have to replace both anyway! GL!
Old Sep 28, 2014 | 10:02 AM
2damax's Avatar
Are you sure? That would really suck! Maybe I should just find someone with a real torch.
Old Sep 28, 2014 | 12:14 PM
Lontar1's Avatar
I would just replace both... saves time.. you can rent the tool to remove the inner one from Autozone, but thats just me
Old Sep 29, 2014 | 04:48 PM
2damax's Avatar
Ok I decided to do this. I have not done an inner tie rod before. I read the autozone tool doesn't always fit perfectly. Anyone have recent experience?
Any tips for the job? Should I replace the boot too? I just put the tool on and twist it off and then twist the new one on with a drop of blue Loctite right? I don't want any surprises.
lowpost99
Oct 26, 2025 06:53 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
camako
Sep 22, 2015 04:27 PM
