Rear Spoiler Removal
Old Oct 3, 2014 | 11:11 AM
FanaticMadMax's Avatar
I was trying to remove my rear spoiler to get it repainted instead of the shop doing it to save on labor cost. Has anyone successfully taken off their spoiler, since I was having trouble getting off since there's a lot of adhesive on it, and I noticed I might have broken a grommet or some plastic thingy on one end, but haven't pulled off the spoiler entirely. Has anyone run into that situation, and is that plastic grommet can replaced or am I screwed?
Old Oct 3, 2014 | 11:46 AM
98.5 SE Max's Avatar
A trip to your local junkyard will solve that problem. Just try not to break the new ones from the donor car. I found for those plastic pin things it's easier to use a screwdriver or something to pry them out. As for the adhesive, you could probably use some 3M double sided tape to replace it.
Old Oct 14, 2014 | 10:36 AM
egali045's Avatar
there's only 3 screws. left middle and right. unscrew them carefully. use that pb blaster or chances are it might break as you're untightening. then pry it and it's easy as it sounds.
The Frye
Sep 2, 2021 11:03 AM
Wolvee
Apr 20, 2018 05:34 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
