P1320 2000 Maxima
Old Oct 6, 2014 | 04:11 PM
Jasonxneo's Avatar
P1320 2000 Maxima
SES light just came on and is showing a P1320. I read through the forums and it says its usually a problem with the ignition coils. There are no other codes which signify a specific cylinder that is misfiring. How do I determine which ignition coil to purchase left of right side? Also the websites that I am checking show that Hitachi are the oem for nissan coils, while other people on the forum says it's hanshin?
Old Oct 6, 2014 | 08:24 PM
Donkeypunch's Avatar
You'll feel the car missfire when it does and at first it'll do it intermittently before it completely fails... Then the code to whatever coil failed will turn on.
The code you have though i've read Nissan will want to change all the coils to the upgraded ones as a fix.
The ecu will see that the signal on your coils are not all the same so it'll throw that code even if they are firing just fine. I have also read that certain plugs could trip the code like Bosch platinum.
In my car I have 3 different types of coils (old style, newer style, and duralast) and never tripped that code.
Also ngk g-power plugs.
Bad old wires could cause the code also.
"Nissan quality"
http://ww2.justanswer.com/uploads/Ar...37_harness.pdf
Old Nov 4, 2014 | 09:10 AM
Jasonxneo's Avatar
I just went to autozone to re scan the CEL to see if any secondary codes for a specific cylinder came up. No luck just the same code.
Attached Thumbnails P1320 2000 Maxima-135262_10151149103274226_310447879_o.jpg
Old Nov 4, 2014 | 02:08 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
"Nissan quality"
Humm your answer is making me think about the spark plugs. I got the P1320 and the car doesn't show or act like having a missfire. Hummm maybe I will change the sp back to NGK
Old Nov 4, 2014 | 02:56 PM
maxfever1987's Avatar
P1320 is directly related to your coils, are you using any aftermarket coils at all?
Old Nov 4, 2014 | 03:56 PM
Daniel VQ30life's Avatar
I had the same code about a year ago and about 2 months later was able to feel a misfire under heavy throttle, after that i was able to get a misfire cyl 6 code, swapped coils with cyl 4, reset codes, and a week or so later when the car misfired again, code came up for cyl 4 (as i had hoped) replaced ALL ignition coils, reset codes again, no issues since
Old Nov 4, 2014 | 07:54 PM
Jasonxneo's Avatar
Yes, 1 of the coils are aftermarket which I changed about 2 years ago. It was one of the rear coils, not sure which cylinder exactly. The rest are original, but since it's not throwing a code for a specific cylinder, I don't want to replace them all if they are working.
Old Nov 5, 2014 | 01:37 AM
tosheto's Avatar
Replace the aftermarket one with OEM one from a local junkyard and your problem is solved.
halfpol
Oct 17, 2022 12:16 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
