02 SE No Start After head unit install
Old Oct 9, 2014 | 06:32 AM
mvarNH's Avatar
Just picked up an '02 SE with 124k miles last week. Drove it around for a few days and got a P0303 code (cylinder 3 misfire). The car would still run rough and drive, so I ordered plugs and coil packs. Yesterday I switched out the head unit with a Pioneer head unit. I left the battery attached and blew the audio fuse. Replaced the audio fuse but now the car will not start at all.
It cranks and fires up for about 1 second then dies, even if I give it gas it will not stay running for more than 1 second. It seems like a fuel system issue to me. Is there another fuse I could have blown that would leave me in this situation. Could a P0303 code cause this? Anything to do with the radio install, or just coincidence?
Old Oct 9, 2014 | 06:50 AM
The P0303 code has nothing to do with this, and everything to do with the radio install. IMO, you blew a fuse, relay or fusible link. Start checking.
Old Oct 9, 2014 | 07:01 AM
mvarNH's Avatar
both 80A main fuses look like this, blown?
Old Oct 9, 2014 | 08:44 AM
Jor's Avatar
Jor
Check the fuse for sure. But first disconect the negative on the battery
Old Oct 9, 2014 | 08:49 AM
mvarNH's Avatar
That 80A fuse was good, fuel pump fuse is good. Next thing I should check is fuel pump relay? Or are there other fuses/relays that come to mind? Is the fuel pump relay behind the drivers side kick panel?
Old Oct 9, 2014 | 09:16 AM
mvarNH's Avatar
Fuel pump relay is good, fuses are all good as far as I can tell. I'm going to try the other relays under the hood.
Old Oct 9, 2014 | 09:36 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
have you look at the fuse on the battery positive terminal?
Old Oct 9, 2014 | 10:05 AM
mvarNH's Avatar
It looks intact, I actually broke it trying to get it out so I cant test it now. Wouldnt that cause nothing on the car to work electrically? As far as I know everything on the car works except what appears to be the fuel pump.
Old Oct 9, 2014 | 10:49 AM
mvarNH's Avatar
okay so the fuel pump is definitely getting power. I just took the back seat off and listened to the pump fire up.
Old Oct 9, 2014 | 02:08 PM
maxima92se's Avatar
Did you pull any codes? Issue sounds like it's related to your stereo install though.
Old Oct 10, 2014 | 10:00 AM
mvarNH's Avatar
turned out to be P1122 and P1126-open throttle body motor relay, only one I didnt check yessterday because it was such a pain to get off. Anyways, turned out to be a good excuse to buy an OBDII screener.
Thanks guys.
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
homeyclaus
Sep 3, 2015 06:15 PM
BunkyMaxima
Aug 22, 2015 12:58 AM
MikesChevelle
Aug 9, 2015 11:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
