Driver window regulator.
My driver side window is stuck completely down. I have bypassed the switch itself, and I am fairly confident that I have a bad motor. I had a few minutes free so I grabbed a couple tools and went to remove the motor for further testing.
Here's where it gets tricky. I've got to remove the glass. However, the retaining bolts for the window to regulator can only be accessed with the glass about 3 inches from the bottom. Mine is too far down to access those bolts from their factory access points. I can't even get a crow's foot on the bolts because of their buried position. Trying to force the glass led to some anxiety as the force holding it causes the glass to begin flexing in a manner that seems sure to cause a need for glass replacement also. I'm not ready for that path just yet.
Any advice from those that have addressed this same issue in the past?
What I did was have a buddy pull up on the window from above while I used a big flat head screwdriver and (using the bottom of the big hole for leverage) gently pried underneath the window guide. We got it up far enough to take off the 2 bolts through the holes, then we removed the window and pulled the whole motor/regulator/guide rail assembly out through the bigger hole in the rear of the door frame.
FYI: Be very careful working in and around those holes with your hands—I cut the back of my hand and mashed my thumb pretty bad fudging around inside those things.
I currently don't have the money for a new assembly (only $105 at my local parts store) so I had my buddy hold the window up tight into its frame and propped it up with a couple boards. It's been holding for the last couple weeks. Just have to be careful closing the door
jsmith24
Feb 1, 2016 12:35 AM
Andy29
Sep 29, 2015 05:32 AM
