2001 full sized spare?
Old Oct 17, 2014 | 07:01 PM
cdoublejj's Avatar
has any one modded the spare tire wheel well to fit a full sized spare?
Old Oct 18, 2014 | 10:40 AM
Dust N Bones's Avatar
A full size spare will fit, you just won't be able to use the particle board cover. You'll just have to put the trunk carpet over the full size spare & the trunk floor will no longer be flat, you'll have a hump. I had a 2001 I30 that came with the factory option full size spare & there was a foam insert between the full size spare & the trunk carpet that was probably there to keep the carpet from sinking into the center of the wheel.
Old Oct 18, 2014 | 01:59 PM
nestorlugo's Avatar
if this is true it looks like a cut and splice job..on the spare wells.. if nothin is on the way down there....i'll call it trunk on full "MOD".
Old Oct 18, 2014 | 05:45 PM
cdoublejj's Avatar
EXACTLY what i was thinking. get some appropriate gauged metal, and some ballpeen hammers and splice in a small extender to make a it a inch or 3 deeper.
Old Oct 18, 2014 | 08:08 PM
Oh it's definitely true, I found a pic of an I30 with a full size spare on cars.com. As you can see the trunk floor isn't flat however with the full size spare it's not raised all that much.
Old Oct 19, 2014 | 06:56 PM
cdoublejj's Avatar
that depends how still the groceries will stay. :P i will have to see how much work it would be and if any thing would bottom out or melt.
Old Oct 19, 2014 | 07:40 PM
nestorlugo's Avatar
Well i like the full size spare idea despite what the grocery bag do....
Old Oct 20, 2014 | 04:42 AM
foodmanry's Avatar
Da Roller Coaster!
I had full size spare with 17's and the hump wasn't bad at all. It was barely noticeable. I also have a second layer of carpet over the factory "carpet" so that helped to even it out.
Old Oct 20, 2014 | 04:48 AM
D.Stillwell's Avatar
^ My old I30 had the 16" full-size spare option, and the trunk was flat. 17"s will raise it just a bit but not much, no big deal.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
