2002 Nissan Maxima IAC Valve Location!
Hey can someone please tell me where the IAC Valve is located? If you can add a picture that would be even better. Ive looked everywhere but cant find a picture! Please help me!
I think i need it because when its cold out sometimes my car dosent idle properly but some times it does and when i say bit properly i mean like the rpms go up and down. Also after lets say driving for a bit and the engine is warm and i park it. Then go back to it after 10 mins while its still warm and start it up the rpms will go from 800 to 300 then back to 650. I dont think it should be doing that. What could the problem be? I just got a parts maxima so i have the parts and im 90% sure the parts are good. So i just need help figuring out what needs replacing and where its located.
Thanks for your reply guys!
Thanks for all your help!
Service Engine light 2003 Maxima SE
My first time on the forum and looking for some help. I have a 2003 Nissan maxima SE that runs great up to 2500 RPM's but cuts out at that point. In park if you rev the car and hold it @ 2500 RPMs it the idle just bounces from 2000-2500. The SES light will not reset or blink and is throwing a 0650 code for defective indicator lamp.
I took it to a local Nissan dealership for diagnostics ($100/hour) and they determined that it had a defective instrument cluster. I replaced it and had the exact same results (even the SES light) so I put the original back in.
I pulled the ecu and sent out for rebuild. Came back and I installed it, fired up the car and it ran great! The SES light never shut off but it ran great at all RPMs. 2 weeks later....I'm back to square 1. Its cutting out @ 2500 RPM.
Any suggestions?
Any suggestions?
A bad maf wont let your car rev pass 2500rpm. Mine wasnt as bad but gave me idle issues. When i took it off my parts car and started the parts car without a maf it wouldnt rev past 2500. I would suggest you change your maf. Its pretty much dead. That should fix your problem.
Good Luck!
Good Luck!
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
