Trans Noise - loud hum?
Old Nov 8, 2014 | 06:36 PM
9146fan's Avatar
2001 Nissan Maxima GLE. Automatic Transmission. 104K miles.
No noise at idle, but there is a rather loud humming noise coming from the front of the car when driving down the road. Car has new tires, but the noise started well after the tires were replaced. Trans fluid has never been changed but color looks OK (not a big deal to change this as I should anyways).
What's the common problem here?
1. Trans going south?
2. Axle/VC Joint issue?
3. Motor mounts?
4. Engine getting ready to implode ?
Old Nov 8, 2014 | 06:40 PM
chrome91's Avatar
does it get louder as the car moves faster? could be a bad wheel bearing if thats the case
Old Nov 8, 2014 | 06:56 PM
Child_uv_KoRn's Avatar
Bad *** Newb
+1
The color is not okay. If it's not red or pink, then it is a big deal.
Old Nov 8, 2014 | 07:00 PM
9146fan's Avatar
Yeah, gets louder with speed. I'll get the wheel bearings replaced up front.
Old Nov 8, 2014 | 07:26 PM
george__'s Avatar
Timken
Or
OEM
Old Nov 8, 2014 | 08:32 PM
Bossmanreuben's Avatar
+1
Don't meant to hijack, but if my tranny fluid is like a blackish brown I should get it changed ASAP right?
Old Nov 8, 2014 | 09:01 PM
george__'s Avatar
Maybe too late now
"Transmission fluid high mileage cars"
Old Nov 9, 2014 | 11:32 AM
chrome91's Avatar
its most likely only one, and dont jump to it being the wheel bearing. but 75% chance that if it gets louder with speed its the wheel bearing. only way to know for sure is to see if the wheel has play and jack both front wheels off the ground, put it in drive, and see if the noise is coming from the wheel bearing with a stethoscope
transmission fluid naturally will go brown over time from heat in the transmission, you can try changing it. if its black, or you change it and the fluid goes black again fairly soon, somethings up with the trans
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
ef9
Oct 4, 2015 08:43 AM
