Manual AE pedals on a 2K2
Old Jan 23, 2002 | 03:04 PM
tso72's Avatar
Has anyone installed them? DaveB isn't sure if the gas pedal assembly will fit. I'd like to get confirmation before I order.
Thanks,
-T
Old Jan 23, 2002 | 03:08 PM
BigDogJonx's Avatar
Re: Manual AE pedals on a 2K2
Thanks,
-T
Not sure about that one, I thought it would not fit since they went to the new DRIVE BY WIRE on the gas pedal. I dont know how that would work at all.
Dixit
Old Jan 23, 2002 | 03:11 PM
tso72's Avatar
Re: Re: Manual AE pedals on a 2K2
Dixit
Yeah, I'm hoping that you can swap the pedal and not the entire assembly.
perrymaxima's Avatar
Thanks,
-T
I have heard of problems with the gas pedals fitting (auto) our 2002 but the guy was able to get it on. I'm not sure of this, but I think either the 2002 6spd or 6spd w/HLSD come with the stainless pedals which would be a better fit than th A.E. pedals.
Old Jan 23, 2002 | 04:54 PM
B1GMATT's Avatar
http://forums.maxima.org/showthread....ghlight=pedals
Here's a pst with them on a 2002 6 spd. I have them laying in a box for mine but haven't gotten a chance to put them on. I don't see why the gas pedal wouldn't fit, I don't think the lever assembly changed - the car just doesn't have a throttle cable anymore.
Old Jan 24, 2002 | 12:01 AM
a33's Avatar
a33
hey i can sell you mine if you are going to order, so if you are planning to order, tell me first and we will work out a price...
Old Jan 24, 2002 | 12:30 AM
emax02's Avatar
The gas "lever" is quite a bit different. The old 3.0 maxima had a hook up for teh throttle wire and the new 2002 has a hook up for the drive by wire sensor.
The solution (as said in the search results above) is to remove the pedals from the levers and install just the pedal on your lever.
Just wait for the 2002 HLSD pedals to come out, they should be out any day.
Old Jan 26, 2002 | 03:25 PM
B1GMATT's Avatar
I installed my 20th AE pedals today. I just removed the gas pedal and it clips right on. The only thing i had to do was fill in the gap with the sleave that was around the AE lever because my lever was not as large of a diameter. Otherwise it was cake. It didn't take more than 10-15 mins.
I was wondering if the dead pedal off the new 350Z will fit the Maxima's. It's a perfect match. Here's a pic if you don't know what i mean. http://www.nissannews.com/nissan/pr_...z120tran01.jpg
Thanks for the tip emax95. It saved alot of time and a potential fit of rage.
Old Jan 26, 2002 | 06:41 PM
How did you get the gas leaver off?
Old Jan 26, 2002 | 07:52 PM
B1GMATT's Avatar
There is a little clip on the back of the pedal on the top. All you have to do is grab a flat-head screwdriver and pop it off. The bottom half of the pedal just pivots on the lever and then slides right out. The majority of the time was needed for the brake pedal which took some elbow grease to get on.
Old Jan 26, 2002 | 08:16 PM
KTM's Avatar
KTM
Those look great!
Old Jan 27, 2002 | 06:36 AM
Sounds simple I read someplace else the brake pedal was a bit$h to put on That's good news because ebay had an auction on the kit but, instead of the whole gas assembly it was just the metal gas pedal and brake cover.
Old Jan 27, 2002 | 08:02 AM
B1GMATT's Avatar
It better come with a new clip and a plastic sleave, otherwise it will be very loose.
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
