knock sensor
1. Remove intake valve timing control solenoid valve.
2. Provide 12V DC between intake valve timing control solenoid valve terminals 1 and 2, and then interrupt it. Make sure that the plunger moves as shown in the figure.
CAUTION: Do not apply 12V DC continuously for 5 seconds or more.
Doing so may result in damage to the coil in intake valve timing control solenoid valve.
NOTE: Always replace O-ring when intake valve timing control solenoid valve is removed.
Is the inspection result normal? YES >> INSPECTION END
NO >> Replace intake valve timing control solenoid valve.
So neither IVT motor actuates when I give it 12v. But I'm not entirely sure I'm getting it power in the proper way. I dont think both of the solenoids would fail...
Cleaning the MAF didn't do anything.
Ive also had a REALLY small oil leak towards the front of the car for a while, always just a few drops. I wonder if these motors are bad, and dumping the oil when I turn off the car?
But I found a few interesting things:
-My intake gasket is TRASHED. Theres not much rubber left, it's not doing anything really. I'll be buying a new one.
-I can hear a vaccuum leak. It's coming from the Vapor Canister Purge Solenoid....
I also dont have the right alan wrench/torx socket to get the throttle body off the plenum. I cleaned one side of it, but couldn't detach it to get the other side. I'm going to get the right tool and try it again.
I think my problem is a vaccuum leak. Probably somewhere in the intake area.....
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
