Car still misfiring. A LOT tried so far
Old Nov 29, 2014 | 10:42 PM
  #41
Child_uv_KoRn's Avatar
Bad *** Newb
OK, this is a big difference about the revs! I thought you had power and it drove normal. I also missed the part about the TB not opening.
I guess you just have to see what happens after swapping it.
Old Nov 29, 2014 | 10:43 PM
  #42
nestorlugo's Avatar
Originally Posted by AcuraLegend
It's late, so I think I;m not explaining clearly Sorry.
All of the REAR bank are OEM coils. I also did all NGK plats on all 6 last week. they're new back there.
My misfire is MUCH less violent. It's not a cylinder deactivating mis anymore. That was fixed by replacing the coil that jumped from 4 to 6 when I swapped it.
My misfire is now really only at idle. Also, no CEL at all if I let it idle. I let it run for 30min, no SES. I took it for drive, still rough idle. Give it heavy throttle and SES come on. I checked it immediately - and no cylinder code - just random misfire. I also notice no change in power when I press the throttle. RPMS rise, but I'm not getting any throttle response. That paired with the fact it wont open when I press the pedal - I think the LAST thing to fix is the TB.
So far it was:
-Dirty IAVT solenoids
-Dirty Plugs (all new)
-Non oem coils - replaced 2
-Destroyed intake gasket
-Cracked PCV gas blowbyhose
-Cracked PCV rear intake hose
I hope that makes sense, it's late
Ok then it's early and therefore they still serve alcohol! so you!,my friend get a drink and relax imo i think bank 1 injectors should be changed or refurbished,if the result on the neighbors car comes inconclusive....otherwise tb next i guess...
Old Nov 29, 2014 | 10:45 PM
  #43
AcuraLegend's Avatar
__________________
Yeah, it never has. Im sorry for not making that clear from the jump!
Old Nov 29, 2014 | 10:47 PM
  #44
I got plenty of beers man. So I'm still all in. Hahaha.
Im just not following the injector logic...
If I pull injector 1 - and cylinder starts missing , I know injector one is passing fuel, right?
I pull injector 3, and the idle condition doesnt change - injector 3 is not passing fuel - and should be changed?
Old Nov 29, 2014 | 10:51 PM
  #45
WOW. I love the web. I just found this (on another site)...
But my cats are hollowed. Are my o2 sensors even working anymore? This may not apply, but the symptoms sound almost identical. I wonder if when they hollowe them out, if they connected the harness backwards.....
Customer:
The valve cover gaskets were replaced recently (a few months before this started)
Customer:
And the engine has been run low on oil in the past. I feared compression problems but the way the problem comes and goes had me wondering
Jay :
Oh
Jay :
Wait a min
Jay :
I want you to check something
Jay :
You mentioned you had valve covers done
Jay :
There is one thing I have seen I would like you to check for me
Jay :
I have seen where 02 sensors on the passenger side can get plugged in backwards
Jay :
I want you to go to the 02 sensors on the passenger side.
Jay :
and If you can do this for me it would help me to help you.
Jay :
what I need you to do is this
Jay :
bank 1 is the passenger side, and bank 2 is the drivers side
Jay :
I want you to look at the wire colors for Bank 1 sensor 1 02 sensor, and Ban 2 sensor 1 02 sensor and give me the wire colors on the harness side of the connector
Jay :
So I can check to make sure they are plugged in correctly
Jay :
Then I want you to do the same thing for the rear 02 sensors.
Jay :
Cause if backwards that can also confuse the computer
Customer:
Are the 1 o2 sensors the ones I see plugged into the exaust manifolds?
Jay :
Yes, there is one in the manifold and after the manifold
Jay :
there is two 02 sensors on each side
Jay :
This can also cause the possible misfire if what I am thinking maybe your problem.
Customer:
I will go look right now... standby
Jay :
Take your time
Lets see if my gutt instinct is right on this.
Customer:
You sir, are a genius.
Jay :
you found something?
Customer:
When I looked at the connectors, I noticed there was a white paint marker drawn across the male and female connectors, but the marks didnt line up. I switched the two connectors, and they matched up perfectly.
Customer:
The car idles smooth now
Jay :
Cool deal
Customer:
That was the kind of thing only a nissan guy would know, anyone else would have just started listed off stuff to replace
Jay :
I know nothing about Nissans...
Jay :
hehe
Jay :
J/K
Read more: http://www.justanswer.com/nissan/6j6...#ixzz3KX27BZAW
Old Nov 29, 2014 | 10:53 PM
  #46
nestorlugo's Avatar
I pull injector 3, and the idle condition doesnt change - injector 3 is now passing fuel - and should be changed?
Not necessary the compression pressure should be tested along with fuel pressure if no malfunction is found check the timing.... Change the $20+ fuel filter that's suppose to last a lifetime and if you really wanna get giggy with it the fps too...
Old Nov 29, 2014 | 11:32 PM
  #47
Bad *** Newb
That should be impossible and it doesn't matter. Wires 1 and 3 are for the heater and the middle is signal.
If somehow the O2s are causing a problem you can just unplug the primaries (or all of them).
Old Nov 30, 2014 | 12:13 AM
  #48
lol yeah, I realized that when I got under the car. I was like :uhhhhh, must be for a different nissan lol
I'm going to try unplugging them tomorrow, and see how it acts.
Old Nov 30, 2014 | 12:14 AM
  #49
I'm not sure if this app can test the fuel pressure, but I'll check it out.
Old Nov 30, 2014 | 02:22 AM
  #50
So there's a really stupid trick I learned. From the 350z forum.....
To get the valve on the TB to open, with the ignition set to on, YOU ALSO HAVE TO HAVE THE CAR IN GEAR.
I put it into 1st, wedged the throttle down, turned ignition to 'on' - And YES the TB valve moves. I also did continuity and power tests earlier, so that saves me some money on a TB.
Old Nov 30, 2014 | 02:25 AM
  #51
No change with the o2 sensors removed (like I thought).
Im running out of ideas. Maybe the fuel filter and if i can figure out a way to test test the fuel pressure, maybe an injector or 2.
I also still might have a vacuum leak. Not sure where, but i'm running out of things to check!
Old Nov 30, 2014 | 02:50 AM
  #52
Bad *** Newb
What's left? Maf and injectors? But I don't see how injectors could cause such power loss.
You still have precats? Clogged cats will cause it to barely have power, but idk about idle.
Old Nov 30, 2014 | 03:01 AM
  #53
Theyve been gutted out. I was getting o2 sensor codes on both banks, so they gutted em.
I cleaned out my MAF as one of the first things. Ive never gotten a code on it, its an expensive *** sensor, I dont want to just replace it.
My diag software on my android phone doesnt test fuel pressure. I know I can get a gauge at AZ, but I don't know what Im doing past that.
Old Nov 30, 2014 | 05:58 AM
  #54
dwapenyi's Avatar
Haven't read the entire thread, but if the misfire is mild, I would look into TCW3. Maybe your injectors aren't totally synced. The ecu assumes the injectors are identical. Anyway, TCW3 makes for a buttery smooth idle and makes your car run quieter.
Also perhaps clean your grounds so all electrical components are "talking" to the ecu clearly.
Old Nov 30, 2014 | 01:15 PM
  #55
Phantasm's Avatar
I second checking this, though I just went ahead and replaced my fuel pump, pretty cheap aftermarket part (it's located on top of the tank under the back seat -pretty easy swap, stinky but easy). This Fixed ALL of my stalling problems and misfire issues SES codes. Gotta have fuel present before anything will combust.
2002 Maxima SE 6spd @ 168k miles
Old Nov 30, 2014 | 01:24 PM
  #56
I'm back in the direction of a vacuum leak.
I'm pretty sure I can hear air escaping right at the intake elbow. Especially when I turn the car off, I can hear a VERY faint hiss at the area of the elbow. Kind of where the Idle Air Control unit is.
I would think fuel injectors would cause stalling or bad hesitation at acceleration. I'm not getting those (anymore).
Old Nov 30, 2014 | 02:54 PM
  #57
Bad *** Newb
I think that noise is normal. You have no IACV :P
Old Nov 30, 2014 | 03:05 PM
  #58
Vapor can vent valve?
Then maybe it is an injector. The idle is definately rougher than normal (but not jumping) and I can hear a knock
Old Nov 30, 2014 | 05:38 PM
  #59
Bad *** Newb
Yeah, purge valve or w/e they call it is nearby.
swap till you drop :P
halfpol
Oct 17, 2022 12:16 PM
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
