Center Console/trim removal
Old Nov 29, 2014 | 07:51 AM
03Alt3.5Biz's Avatar
My new (2000) Maxima has a thrashed center console. The right arm rest looks like a dog has been chewing on it. The trim around the manual shift **** and up towards the dash is scratched up. I managed to remove the trim around the shifter but cant get the shift **** off. How do I remove the shift **** and the trim around the stereo without breaking it? Any instructions or pics on the forum?
My goal is to: replace the arm rest pad, replace the shift boot, repaint the trim pieces.
Old Nov 29, 2014 | 09:14 AM
Ephraim's Avatar
Ya, there are instructions, try searching for 'center console' or something to see pics.
IIRC though
-manual shift **** hand screwed on (no hidden set screws), just turn it by hand and it comes off with some effort. Normal threading, not reverse
-Fan vents above the stereo 'pop' out with a little bit of effort and careful prying
-fold open the ash tray thing, pull out the box in it, behind it is a phillips head screw
-slide driver/pass seats forward a little bit, which will reveal a phillips head screw on either side of arm rest console
-open arm rest console (if you want it out too, otherwise not needed for radio console area removal), remove phillips head screw on bottom of storage area (iirc, maybe not though)
-other screws reveal themself for the radio trim and cabin control when fan vent piece & cig-lighter/e-lights trim piece removed
When you remove panels (which I think you can now do), there are pop-tabs, they wont break but you can bend or misplace them easily. Consider using a flat head screw driver to carefully pry the panels out. Also the cig lighter and e-light button are connected to wires which pop off easily. Engage the park brake at some level and arm rest console slides past it. Just take your time and it is straightforward.
Old Dec 7, 2014 | 09:23 AM
Thanks, good info. So the shift **** comes off counter clockwise? I have applied a lot of force and it wont come off. What does the stock shift **** look like? Mine is a black ****.
Old Dec 8, 2014 | 06:07 PM
Ephraim's Avatar
Honestly I dont remember which way it is threaded, I would guess regular. Black leather ****?
Old Dec 8, 2014 | 07:04 PM
its actually a black plastic ****. No gear markings. Not stock?
Old Dec 10, 2014 | 03:16 PM
Ephraim's Avatar
Probably not stock then, but someone else is gonna have to chime in. Mine was black leather with gear markings.
Old Dec 14, 2014 | 01:59 PM
Max56's Avatar
The shift **** has a standard threaded. I'm really surprised that yours is that tight, since every car I have owned the gear shift ****, including my 03 SE, gets loose after a while.
Old Dec 14, 2014 | 02:54 PM
Daniel VQ30life's Avatar
The leather probably came off,that's what happened on mine
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
