Faulty IACV?
Old Dec 2, 2014 | 04:24 AM
m_ouwerkerk's Avatar
Faulty IACV?
Hi, my Maxima keeps fighting for euthanasia, but I won't let it go!
It's latest symptom is that sometimes (maybe every 2nd day or so), when idling, the revs drop suddenly. It doesn't stall, and quickly recovers. It might do it a couple of times within 5 -10 seconds, and then not again for a couple of days.
No problems with normal driving, only happens at idle.
Shouldn't be the coil packs (replaced those about 30k ago), so I'm guessing the IACV - sound reasonable? Anything else that could cause that?
Thanks for any ideas.
Old Dec 2, 2014 | 11:25 PM
Darkrock's Avatar
Hi,
What year Max? I can maybe help if it is a 2001. It does make a difference because you have a voltage problem. You can guess at IACV or maybe TPS or maybe motor mounts or by-pass of IACV issues. It is all here. Along with you have a bad batch of fuel.
Old Dec 3, 2014 | 12:07 AM
Faulty IACV
Hi, the year is 2000, so should be same as 2001.
It's definitely not motor mounts, I swapped these out recently for non electronic. Also can't be bad fuel, has been doing it now for a few months.
Old Dec 3, 2014 | 06:27 AM
nestorlugo's Avatar
It's definitely not motor mounts, I swapped lthese out recently for non electronic. Also can't ljbe bad fuel, has been doing it now for a few months.
Remove the tb and iacv clean them really good ,and you should be ok proly...
Check your grounds by the oil fill hole...
I added a catch can to the pcv sys on mine a few weeks ago and EVERYONE Should TOO!(I've been intercepting about 1oz of oil every 25-30 mi to me thats alarming,,,btw a iacv code popped up it should be unrelated but who knows.
Do you have a cel?
Old Dec 3, 2014 | 04:13 PM
Thanks. What's a cel though?
Old Dec 3, 2014 | 04:26 PM
nestorlugo's Avatar
Cel: check engine light
Old Dec 3, 2014 | 08:55 PM
No check engine light shows.
Derrick2k2SE
Nov 19, 2015 10:14 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
