Altima transmission compatibility
Anyone know if an auto transmission from an '03 Max will fit in an auto '02 Altima?
They seem to have different part#'s but that doesn't necessarily mean anything.
http://www.altimaforums.net/4spd-transmission-info-thread-re4f04b-t6041.html
You could also consider buying a used transmission from your local auto wrecker. If that is the route you choose be sure include in your search the 4spd out of a Nissan Maxima. There are a lot of Maxima’s out there with the same RE4F04B transmission. Just search for a 03 Maxima auto and you should come up with a lot more options, and, at least in my case, cheaper options as well. Just make note that the Maxima 4spd has a shallower transmission pan then the Altima so the Altima transmission filter will not fit. It’s very simple to swap the pan from the Altima transmission to the Maxima unit.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Dec 12, 2015 09:39 AM
trsandrew
Oct 25, 2015 02:47 PM
