ECM Bad or good?
Old Jan 12, 2015 | 03:01 PM
iShiraz's Avatar
ECM Bad or good?
I finally got the ecm out of my car. Can someone tell me if this ecm needs to be repaired? It doesn't look like anything is wrong with it. How is supposed to smell? Someone please help
Old Jan 12, 2015 | 06:01 PM
cornholio's Avatar
from the pic you posted there's nothing that jumps out to me as bad, but it's still a little blurry and only from one angle so idk. check these chips real good for signs of burning/failure:
i think the bottom left one is the one that commonly fails. you should probably notice some sort of burnt smell if it's bad.
Old Jan 12, 2015 | 06:37 PM
maxiiiboy's Avatar
Originally Posted by cornholio
from the pic you posted there's nothing that jumps out to me as bad, but it's still a little blurry and only from one angle so idk. check these chips real good for signs of burning/failure.
+1.
Yes, the ECU board looks OK. You have nothing to loose - go ahead and assume it's good.
Old Jan 12, 2015 | 09:40 PM
DennisMik's Avatar
+2
The parts circled by cornholio are STA509A integrated circuits. These can physically burn up if you have a problem with the IACV (Intake Air Control Valve) or the electric motor mounts (automatic transmission only).
Why did you pull the ECM out?
Old Jan 12, 2015 | 10:37 PM
iShiraz's Avatar
+2 The parts circled by cornholio are STA509A integrated circuits. These can physically burn up if you have a problem with the IACV (Intake Air Control Valve) or the electric motor mounts (automatic transmission only). Why did you pull the ECM out?
IACV went bad. The ecu needs repair
Old Jan 13, 2015 | 05:56 AM
nestorlugo's Avatar
You could be more specific Shiraz and give out a lil more info(i.e. Burned smell when your car died)
I forgot to tell you make sure the iacv you bought is oem since it's recommend here as the only good option,but it's quite pricey.
When your ecm comes back you can do a lot more troubleshooting per the Fsm but you'll need to buy a volt(ohms) reader.
Old Jan 13, 2015 | 08:17 AM
The_Fixer's Avatar
The 509 is burnt and the 2 signal traces overheated
Old Jan 13, 2015 | 08:19 AM
The_Fixer's Avatar
I do ecu repairs for $100 6month warranty with proof of iac purchase and replacement
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
25
Aug 28, 2015 10:15 AM
ChrisIve
Aug 22, 2015 03:04 PM
doobadoo
Aug 15, 2015 06:43 PM
