02 maxima- fuel pump notpumping fuel after replacement
Old Feb 6, 2015 | 09:45 PM
koukimonstrrb25's Avatar
So after replacing the fuel pump,filter and reusing original strainer, the fuel pump is running when priming but not pumping fuel. due to new parts being retrofitted to fit multiple applications, minor mods had to be made to allow the assembly to be reassembed. I.E sanding of plastic pieces to allow reassembly of fuel pump assembly.also the new strainer wasnt able to used as the bottom cap wouldnt fit onto bottom of pump. Also the grommet that seats pump to bottom cap was left out. but everything was assembled correctly. fuel pump buzzes but doesnt pump fuel. also fuse was resinstalled under steering column. any ideas?
Old Feb 6, 2015 | 10:18 PM
nestorlugo's Avatar
Yes put it back how it goes...
Old Feb 7, 2015 | 11:33 AM
lo i did! the assembly is all connected together strainer and all. i did notice when comparing old and new, pumps side by side they stuck together magnetically. ive never heard of this being an issue but is there any possibility this could have caused a problem?
Old Feb 7, 2015 | 11:54 AM
nestorlugo's Avatar
If you purchased the "right" pump and filter ,no modification should be needed at ALL!... unless you broke something....
Old Feb 8, 2015 | 02:21 PM
pump filter and strainer were all ordered off amazon. both of which vehicle fitment was confirmed. ill post back with pics later tonight
Cotozic
Jun 28, 2017 08:01 PM
pkfinn
Jan 3, 2016 02:55 PM
neilraz
Sep 11, 2015 07:36 PM
00MAXI
Sep 2, 2015 10:23 AM
homewrecker
Aug 24, 2015 08:56 PM
