throws into limp with no codes
I have a 2002 maxima 6mt with 54000 miles. My maf went out on me so I went and for a new (not oem). I also gutted my cats and installed a brm 3" exhaust,an intake,and nwp bop
Long story short everyone I Rev up to vvt (4200rpm) it nosedives into limp mode. I can shut off the car for 30 seconds and it turns off limp mode. I'm confused because since I did alot that work the SE light hasn't turned on. ..even when it is in limp mode.any help is needed.
fwd
I took the rear valve cover off for over a month and the cams were exposed. I cleaned them very well and flushed oil. The car has a hesitation if I Rev from idle btw. So I'm leaning towards tps. But I also unhooked the coolant lines to the tb so maybe something got in here?
Disconnected the coolant lines from the throttle body permanently as in bypass? Either way this wouldn't create your problem. This is an engine coolant line, so there is no connection into the air passage for the intake manifold.
It is same thing for the cams. Any dirt would end up in the oil and get trapped by the oil filter. Even if the dirt wasn't trapped by the filter, it would destroy the bearings and things, but wouldn't cause limp mode.
One thing you may want to check is the flexible tube between the MAF and the throttle valve body. If it cracked and is leaking air, this creates problems.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
