isn't throwing a code!!! whyyyy
Old Feb 26, 2015 | 03:15 AM
Jord61194's Avatar
I have gutted cats, intake, new maf, nail delete, and my car is going into limp mode when I hit vvt at 4200. But it won't throw a damn code.... wth. Sometimes the security light 2will flash( idk if that is pertinent info)
Appreciate the help ladies and,gents. Love you lol
2002 nissan maxima SE 6mt
54000 miles
Old Feb 26, 2015 | 05:15 AM
colt149's Avatar
54000 miles
Hook up your vehicle to OBDII scan tool with live feed to detect specific error code and impending error code. Clean the MAF sensor.
Old Feb 26, 2015 | 06:58 AM
NmexMAX's Avatar
dot dot dot ...
Sounds like an IVT code, pending. That's what will do you into limp mode. And when you say limp mode, I assume, it's in fail safe mode, as in your max speed is like 3 MPH or so. Or is it limp mode as in, does not rev over 2500, but until it gets to 2500, it revs normal as in you could go about 55-60MPH down the highway with no problems, until you reach that 2500 RPM threshold?
Old Feb 26, 2015 | 08:08 AM
Jord61194's Avatar
It is limp mode. Basically I'll accelerate to 4G and it will nose dive and go into limp mode till I shut car off and restart it.
Old Feb 26, 2015 | 11:59 PM
dch95's Avatar
54000 miles
I'm not sure what "nail delete" is. When you gutted your cats, did you install an O2 simulator or something that tells the computer your cats are installed and sending the proper signal? If not, your car won't run until this is fixed. Also is it the check engine light that is flashing? If so, this is a huge problem and must be fixed ASAP. If not, you might damage the engine beyond normal repair.
Old Feb 27, 2015 | 04:01 AM
Jord61194's Avatar
The vais is the variable air induction system. A butterfly valve in the plenum more or less... no flashing engine light. The security light is next to the center digital clock. But even with out o2 Sims it should throw a code. And exhaust doesn't set ca into limp mode
Old May 8, 2016 | 04:43 PM
96SEmaxB's Avatar
I'm am having these same symptoms but with codes on my 2002, it started with a torn coupler in my intake, now I think the MAF is shot, rough idle won't go above 2500rpm (like a rev limiter)
p1614 (Nats)
p1130
was running last week but I think maf finally died, checked coils and no vacuum leaks...
Old May 8, 2016 | 07:35 PM
Derrick2k2SE's Avatar
The car will run fine without the secondary o2 sensors. The worst that will happen is it'll throw a code.
Old May 9, 2016 | 06:07 AM
maxinout93's Avatar
So how do you get the car out of limp mode. This is similar to what my car is doing. I can do 55-60 mph fine. Anything higher feels like im hitting a rev limmiter
Old May 10, 2016 | 02:41 AM
DennisMik's Avatar
As best I can figure out from reading the FSM, having a 2400 rpm limit is a MAF problem.
Old May 10, 2016 | 05:38 AM
96SEmaxB's Avatar
Awesome
Old May 10, 2016 | 10:08 PM
maxinout93's Avatar
Thanks for that chart dennis I do notice the cooling fans running a lot. and it Wil pull to 3k until after 4th gear/automatic by the way.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
