Coil #5 REPLACEMENT HELP!!!!!
Old Mar 3, 2015 | 03:23 PM
paulpearl's Avatar
Can someone please tell me how to easily replace coil #5? I took it out because of the P305 code. It is a pain in the a$$ to get back in... I don't want to have to remove or loosen the throttle cable. PLEASE HELP!!
Old Mar 3, 2015 | 04:08 PM
nestorlugo's Avatar
It's just a cable don't worry....just note the position of the nuts or mark them with a Sharpie
Old Mar 3, 2015 | 05:22 PM
george__'s Avatar
Use OEM OR Hitachi ONLY.
If the plug tab thingy seems to be stuck try using a tiny flat head screw driver (used to fix laptops / electronics) for help
Old Mar 3, 2015 | 05:29 PM
vqmaxman's Avatar
I always remove the throttle plate and the bracket on top of the manifold to get the #5 coil out, it's more room that way.
Old Mar 3, 2015 | 07:01 PM
Mateen995's Avatar
If you have a cylinder #5 misfire & you have a 5.5gen it may not be a faulty coil. The faulty valve covers leaks oil into the 5th cylinder spark plug bank. If the boot is covered in oil replace the rear valve cover with a 6th gen kit.
Old Mar 3, 2015 | 07:08 PM
paulpearl's Avatar
I replaced the spark plugs this weekend with OEM NGK's. I ordered a Hitachi replacement coil for #5 and didn't notice any oil on the spark plug upon removal or on the old coil pack boot. So I am hoping its just the coil since no oil was present. I am going to try and remove throttle plate and bracket to make my life easier upon installation. Thanks for the response from all of you.
Old Mar 3, 2015 | 08:58 PM
george__'s Avatar
If you're already ripping out the manifold may as well fix up the valve cover.........
Old Mar 3, 2015 | 09:11 PM
nestorlugo's Avatar
Read please guys....No throttle cable on 5.5 gens
Old Mar 4, 2015 | 05:49 AM
Mateen995's Avatar
whoops, apologies
Old Mar 4, 2015 | 05:49 PM
vqmaxman's Avatar
you have never stated, if you have a 5.5 3.5 or a 3.0.
Old Mar 4, 2015 | 06:15 PM
paulpearl's Avatar
It's a 2001 3.0
Old Mar 4, 2015 | 06:22 PM
Mateen995's Avatar
it was kinda implied when he mentioned throttle cable, I did not see that earlier
Old Mar 5, 2015 | 07:18 AM
NmexMAX's Avatar
dot dot dot ...
Old Mar 5, 2015 | 05:36 PM
vqmaxman's Avatar
The 95-01 maximas have throttle cables and throttle body. The 02-03 maximas have a electronic throttle brive by response,no butterfly flaps for the throttle cables. I guess, I just skimmed the whole article. It's always less confusing explaining what you got. I hope you got the car in the right direction with the right parts.
Old Mar 6, 2015 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
Incorrect, there is still a butterfly flap in the 02/3, just controlled electronically and not by cable.
Old Mar 6, 2015 | 11:10 AM
vqmaxman's Avatar
I was talking about the thing that the cables hook into that circler flap thing that holds the two cables on the tb.
Old Mar 6, 2015 | 12:29 PM
NmexMAX's Avatar
dot dot dot ...
Pretty sure we all know what the point is, so, moot point on both our ends.
Old Mar 6, 2015 | 03:20 PM
acw's Avatar
acw
Yeah...looks like a pain in the **** job (but, i've never gotten back there).
How did you change the plug without moving the throttle cable?
Old Mar 6, 2015 | 04:02 PM
vqmaxman's Avatar
The 3.5 needs the cover and the mannifold plenium to come off to do the back three.
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
evonder73
Sep 1, 2015 02:21 PM
Maxboy23
Aug 21, 2015 11:02 AM
