5th gen Big Brake Kit upgrade Finished
Old Mar 7, 2015 | 07:14 PM
Blake2000's Avatar
FINALLY 🙌🙌 I finally finished my big brake kit today for my front brakes, calipers, rotors, and I also added ceramic brake pads. I wish i could show u guys im doing this from my phone. The pics are on my profile your welcome to take a look.
Old Mar 7, 2015 | 08:00 PM
DennisMik's Avatar
You definitely added some braking power. What is the diameter of the rotors you used and what size rims do you have?
Old Mar 9, 2015 | 11:18 AM
Blake2000's Avatar
I have 17s for rims.... I got the rotors from a 6th gen Maxima so im not sure about the diameter but there's definitely a noticeable difference in size...
Old Apr 2, 2015 | 11:14 PM
maxiiiboy's Avatar
Did they fit without any problems?
The 6-Gen rotors are 12.58" in diameter vs. 11.02" for ours, so they are almost 1.5 inches larger. They must be heavier, too. Did everything work out just fine?
Edit: My car has the "factory 17"" wheels; will the 6-Gen rotors fit?
Old Apr 3, 2015 | 05:21 AM
Prophecy99's Avatar
search a lil harder, there were one set of oem 5th gen wheels that didn't fit the 6th gen bbk, i think it was 5th gen non se wheels, but search its out there.
Old Apr 3, 2015 | 10:57 AM
nestorlugo's Avatar
Huh?
This went on the car flawlessly !! He has 17" se rims.
Btw the rotors were heavy af...
Old Apr 3, 2015 | 05:21 PM
Blake2000's Avatar
To quote nestorlugo they fit perfectly lol... I have pics on my profile or just check my other threads on my profile
Old Apr 5, 2015 | 01:17 PM
maxiiiboy's Avatar
That's good input.
The reason I am so stubbornly asking this question: I clearly remember an earlier post that stated that the 17" SE rims from the 5-gen will not fit, whereas the 17" SE rims from the 5.5-Gen will accommodate the 6-Gen rotor & calipers. I also have a note somewhere that a clearance (measure radially) of 7 5/8" is needed. I don't think my rims provide it .....
Old Apr 5, 2015 | 05:13 PM
nestorlugo's Avatar
That's good input.
The reason I am so stubbornly asking this question: I clearly remember an earlier post that stated that the 17" SE rims from the 5-gen will not fit, whereas the 17" SE rims from the 5.5-Gen will accommodate the 6-Gen rotor & calipers. I also have a note somewhere that a clearance (measure racially) of 7 5/8" is needed. I don't think my rims provide it .....
Go for it dude!!!.... Look what i had to do hopefully they'll fit my16".
Old Jan 21, 2016 | 06:43 AM
losifanatic's Avatar
So what is all needed? Just calipers, rotors, and pads?
Old Jan 21, 2016 | 09:44 AM
a33_ridah's Avatar
Yep. its a direct bolt on with pads, caliper and rotor. Interesting this topic and mods gaining recent traction, oldest of news.
Take this opportunity to bleed all 4 corners of all old fluid in the correct sequence. My reservoir is clear since doing this upgrade
5.5 gen over 6th. 12.6" as stated above by a user is correct.
Old Jan 21, 2016 | 10:33 AM
Awesome! Thank you. I have had no issue warping the front rotors on my 5.5.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
subwayhello
Aug 23, 2015 05:18 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
