Whistling sound front right
Old Mar 7, 2015 | 09:14 PM
egali045's Avatar
So I hear this whistling low sound on the front right behind the wheel. I hear it even when the cars not on. At first i thought it was the tire losing air but it didnt go flat. it sounds like it though. It all happened today after the mechanic replaced the 2 front belts and I drove thru the alley to get home. What is this sound? Any one know?
Old Mar 8, 2015 | 01:57 PM
chrome91's Avatar
so youre hearing the sound with the key off and the engine not running?
Old Mar 8, 2015 | 04:41 PM
egali045's Avatar
Both turned on and off.
http://youtu.be/lmlz6LklNYY
Check it out
Old Mar 8, 2015 | 05:32 PM
2kMaxim's Avatar
Check it out
Pretty sure that's your tire losing air. MAYBE a high pressure line venting from a small leak but less likely.
Old Mar 8, 2015 | 05:36 PM
george__'s Avatar
Tire + crappy wheel installation?
Did you use PSI gauge and check tires?
Maybe it's aliens
Old Mar 8, 2015 | 06:31 PM
egali045's Avatar
So everyone agrees that the tire might be bad. I have not checked tire pressure. Also is that why I hear the grinding sound of the brakes on that same side? They were installed last week but it sounds very bad the last 3 days. What could it be?
Old Mar 8, 2015 | 06:40 PM
george__'s Avatar
Check!!
Old Mar 8, 2015 | 06:43 PM
chrome91's Avatar
could be the clips misaligned or the backing plate rubbing
Old Mar 9, 2015 | 10:02 AM
egali045's Avatar
It was the back plate causing the grinding sound! and it was the tire losing air, took it to the tire shop and they said it had a nail. Damm it but they fixed it and when they took out the wheel, I had space to see if there was anything rubbing on the rotor , and sure enough the back plate was touching it! I bend it back just a little since I didn't have tools. but yea problems solve!
AcuraLegend
Oct 17, 2016 08:47 PM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
