emission codes
Old Mar 16, 2015 | 02:29 PM
scorpiokll's Avatar
emission codes
I have service engine codes p1448,p1800, p0444 and p0455. I replaced the caniater and vent valve with junkyard parts and tested the purge valve (that is working fine no leaks). When i checked the codes before i replaced the parts the p0444 wasnt there. Could this be the sensor? Anyone else have these codes, if so what did you replace? I dont want to dump money on parts i dont need..
Old Mar 16, 2015 | 10:32 PM
DennisMik's Avatar
P0444 & P0445 - EVAP canister purge volume control solenoid valve
P1448 - EVAP canister vent control valve
P1800 - VIAS control solenoid valve
The EVAP canister vent control valve is bolted on to the charcoal EVAP canister behind the left rear wheel. I think you are trying to say you replaced this and if you did, you got a bad part.
The EVAP canister purge volume control solenoid valve and the VIAS control solenoid valve are under the hood, bolted to the engine's intake manifold.
See page 24 in the link below for the location of these parts.
http://boredmder.com/FSMs/Nissan/Maxima/2003/EC.pdf
In the index at the front of the document, look up the Pxxx code and read more info about it, such as how to test the part.
Old Mar 18, 2015 | 08:04 PM
scorpiokll's Avatar
Thanks I will look into testing those parts!
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
