Loss of power p0455, p0011, p1448
Here we go again, so I have a 02 Max GLE auto tranny 127,000 miles everything stock. A while now I been experiencing a loss of power, its been getting progressively worse over time. When accelerating slightly there's sort of a rattling sound that also gotten louder. You only hear it under slight acceleration, under load the sound is gone. I also hear the same rattling noise at start up.(Mainly cold starts) I had no check engine light so wasn't sure where to start. Yesterday my check engine light came on codes P0455, P0011, P1448, P1615. I'm not sure if these codes have anything to do with the loss of power I've been experiencing. The last code P1615 is for the anti theft system, I'm sure its unrelated to the others. I'm sure its one malfunctioning part causing the other codes to go off. Can anyone point me in the right direction so I won't have to change a bunch of parts before I get it right. Thanks in advance
EL.PDF
P1615 - NVIS (NISSAN VEHICLE IMMOBILIZER SYSTEM — NATS)
EC.PDF
P0455 - EVAP CONTROL SYSTEM...
P1448 - EVAP CONTROL SYSTEM...
P0011 - RELATED TO CRANKSHAFT POSITION SENSOR
^^ COULD BE CAUSE OF PROBLEM
FSM LINK
EC.PDF
FSM LINK
also that rattling is your timing chain tensioner on its way out, I would advise to let the car warm up a bit before driving until you can fix it
as said above, the P0011 code might be your problem, if you're going to replace that sensor, OEM only please
Also I have a extra crankshaft sensor I bought I'll change it maybe later or 2morro to see if it makes a difference
TallTom
57
Oct 14, 2025 05:16 PM
