2003 Maxima Problem
Old Apr 3, 2015 | 06:06 AM
jimmyb222's Avatar
2003 Maxima Problem
A while back the left front power window stopped working and I never got it fixed. This week both the right front power window & the power door locks stopped working at the same time. The back power windows still work just fine. Any suggestions on what is causing this.
Old Apr 3, 2015 | 08:38 AM
Maxgig's Avatar
More likely than not its probably the main switch on the drivers door. I had an 03 SE and my passenger side door stopped working so I logically replaced that switch and it still didn't work.
Luckily when I was at the pick n pull I bought all 4 switches, so I swapped out the drivers door and everything was fine. Good luck.
Old Apr 3, 2015 | 02:04 PM
jimmyb222's Avatar
Thanks for the reply. Just seemed odd that on the driver side control panel the power door lock and front power window buttons didn't work but
the buttons for the back power windows did work
Old Apr 3, 2015 | 03:11 PM
nsnrider's Avatar
master window switch malfunctioning. make sure you replace it with the same year max as yours if going with used.
Old Apr 3, 2015 | 03:37 PM
jimmyb222's Avatar
Lakersallday24
Nov 7, 2024 07:31 PM
wingsfan24
Aug 15, 2015 07:35 PM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
09maxshawn11
Aug 9, 2015 01:13 PM
