Right rear suspention banging, please help.
Old Apr 8, 2015 | 04:59 PM
00 Max's Avatar
When I go over a medium size bump the right rear rattles like a shock or something is loose. I have owned my car for ten years and now it sounds like an old pos. The shocks were just replaced, passenger side twice & today. Energy suspention trailing arm bushings are also new.The exhaust is not hitting anything either. I thought after having A new monroe sensa trac strut unit with the spring I was sure it would be fixed. Two seperate mechanics tell me everything is tight. The only thing I have not chainged is the Lateral link. Please tell me what to look for.Thanks. Brian.
00 Maxima se
Old Apr 8, 2015 | 06:32 PM
nestorlugo's Avatar
Pull your e brake one click when your going over bumps see if the noise goes away.
If it does then your rear caliper hardware needs a look over to make sure everything was installed correctly
Old Apr 8, 2015 | 06:39 PM
george__'s Avatar
Top mount?
Old Apr 8, 2015 | 09:44 PM
00 Max's Avatar
Nestorlugo: I would have never thought of that, I will check tomorow and report.
George: Mounts are new.
Thanks guys.
Old Apr 9, 2015 | 08:13 AM
CMax03's Avatar
00 Maxima se
Suspension....
Chickens in a coupe! Rear strut mount rod bushing loose....
Old Apr 9, 2015 | 08:27 AM
00 Max's Avatar
Does that come installed on a premium quality 1 day old complete strut assembly (reading off the box)?
Old Apr 9, 2015 | 08:31 AM
00 Max's Avatar
Can a new es trailing arm bushing shift? What would happen if a lateral link bushing is bad?
matts95max
Apr 23, 2025 10:44 AM
ef9
Sep 5, 2015 11:18 PM
