power valve assembly
Old Apr 22, 2015 | 12:07 PM
sterl_worl's Avatar
hi,
03 se 6spd high miles, just replaced firewall side cat and cleared all codes except "multiple misfires" ughhh!!! my question/problem is when going uphill the car loses power big time as well as starves if/when i put my foot into the accelerator. so when checked out we found that the "power valve assembly" is taking in air when spraying carb cleaner around intake for leaks...well i was told i needed an Intake Valve Timing Control Solenoid Valve; cannot find this part anywhere in existence the closest thing its been identified to is power valve assembly. ok needless to say i dont have a clue...but i do know its on the passenger side of the motor and its right on the manifold and it has a rod connected to it similar to like a throttle and its secured by i think 3 hex bolts. Can somebody please please help me????
Old Apr 22, 2015 | 01:14 PM
george__'s Avatar
Maf
Old Apr 22, 2015 | 03:53 PM
DennisMik's Avatar
The Intake Valve Timing Control Solenoid Valve advances the camshaft and uses an electric motor to do that.
It sounds to me like you need the power valve.
This is Nissan part # 14510-8J19E. I don't know if you can get these at your local auto parts store or if it is a dealer only part.
http://www.nissanpartsdeal.com/parts...510-8j19e.html
Old Apr 24, 2015 | 01:35 PM
sterl_worl's Avatar
yes...the bottom 2 pics is exactly the part i was trying to describe. thank you so very much!!!!!!
Old Apr 29, 2015 | 01:44 PM
sterl_worl's Avatar
well i replaced both parts solenoid and power valve and guess what...car still idle once warm at abou 600rpm as well as when i drive and give it gas it feels and sounds like its starving as well as very little power. i cant afford to keep buying and trying things is there any help/hope for me? obd code is multiple misfires ive checked coil packs changed plugs replaced cam position sensors cold air intake rubber boot firewall side catalytic converter....i am definitely clueless and appreciate any/all help guidance you guys can offer. thanks again for all help
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Bluenissan
Sep 20, 2015 08:54 PM
bumpypickle
Sep 19, 2015 01:07 AM
tardrex
Sep 11, 2015 07:35 PM
