WEIRD Side Marker flash
Old Apr 25, 2015 | 12:50 AM
Blake2000's Avatar
I having a little problem..... My side marker lights come on when i put my foot on the brake to slow down and when im in park and my headlights are off an i go pump my brakes they turn on ...... Any idea what this could be??? Wiring of some sort or should i get them wired to sync w my headlights???? ALL OPINIONS ARE WELCOMED........
Old Apr 25, 2015 | 11:00 AM
cornholio's Avatar
is it both the front and back?
if just the back maybe previous owner tried to wire it with the blinkers and got the brakes instead? i'd think it'd be harder to get the front ones to do that though
Old Apr 25, 2015 | 08:19 PM
DennisMik's Avatar
It may be that someone changed one og the front turn signal light bulbs and put the wrong light bulb in. The front turn signals use an 1157 lamp, which is a dual filament bulb. The probably put in an 1156 lamp, which is a single element bulb.
Old Apr 26, 2015 | 11:14 AM
george__'s Avatar
I have to occasionally hit my rear ones with my hand... They are aftermarket ebay ones though with built in light bulb
Old Apr 28, 2015 | 12:52 PM
Harquebus's Avatar
Had a similar problem with my Saab once. Almost all the lights on the car started acting funny. The brights didn't work and the turn signals didn't blink, just glowed steady when activated and it was due to a rusted off ground (or "earth") bolt in the rear hatch area. There was a leak there once and the moisture rusted through the bolt that a ground wire was attached to. I just relocated the wire to another nearby bolt. Check your vehicle ground points, it could be as simple as that.
Old May 3, 2015 | 08:08 PM
Blake2000's Avatar
Yea its both front and back
Old May 3, 2015 | 08:12 PM
Blake2000's Avatar
Thanks if its a ground, im gonna put a new grounding kit on my car
AaronL
Nov 15, 2020 11:52 AM
bryants95max
Oct 2, 2015 12:52 PM
bennuss
Sep 11, 2015 05:55 AM
Colossus
Sep 9, 2015 05:46 AM
intimidator
Sep 5, 2015 07:23 PM
