2001 maxima abs sensor location to all 4
Old Apr 29, 2015 | 11:11 AM
kidwill613's Avatar
I need help
looking for the 4 location to the abs sensor on my car my abs sensor is on so instead of changing one decided to change all 4 just need help
Old Apr 29, 2015 | 01:43 PM
Derrick2k2SE's Avatar
They're mounted to each hub assembly with one 10 or 12 mm bolt. Pull the wheel and look for the thick black wire coming from the car to the hub. That will lead you right to it. Undo the bolt and wiggle the sensor out.
Old Apr 29, 2015 | 10:40 PM
maxiiiboy's Avatar
Originally Posted by kidwill613
I need help
Get yourself a copy of the FSM (Factory Service Manual). You can download it from here http://www.nicoclub.com/FSM/Maxima/ . BTW, you'll need all sections.
The FSM will tell you not only where the various parts are located, but it will also tell you how to fix the most common problems.
Old Apr 30, 2015 | 10:25 AM
FanaticMadMax's Avatar
they are bolted right behind the splash brake dust shield. Not hard to find.
mrc00l88
Jan 25, 2024 01:14 PM
District
Aug 15, 2015 08:23 PM
wpr
Aug 5, 2015 03:28 AM
