replacing the front fans
Old May 6, 2015 | 11:42 AM
bennuss's Avatar
I need to replace my radiator that cracked on top and one of the fans sounds like it is wobbling and rubbing against the radiator. Should i replace the whole shroud with fan motors or just that fan side with the motor? any recommendations ?
Old May 6, 2015 | 12:42 PM
jrod23's Avatar
I would replace the total assembly. I replaced the total assembly with one from Auto Zone 3 years ago and both fans are still going strong. The fan assembly was around $270.00 I installed the assembly myself and it wasn't too difficult of a job. Keep in mind you have to remove the top radiator hose and some fluid may leak out when disconnecting that hose. Good luck - Jared
Old May 6, 2015 | 02:38 PM
Derrick2k2SE's Avatar
Just get the fan unless the assembly is damaged. The fans alone are way cheaper. I replaced both of the fans on my wifes car last year with no problems. I think the fans were around $60 each and they're the only part of the assembly that wears out.
Old May 6, 2015 | 02:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
270 LOL 88 bucks on ebay for TYC.
Old May 6, 2015 | 05:08 PM
george__'s Avatar
Wow even I didn't pay $300 for those two fans
Old May 6, 2015 | 07:51 PM
Donkeypunch's Avatar
$95.34
prime shipping.
Amazon.com: Dorman 620-416 Radiator Fan Assembly: Automotive Amazon.com: Dorman 620-416 Radiator Fan Assembly: Automotive
Amazon.com: Dorman 924-425 Radiator Bushing: Automotive Amazon.com: Dorman 924-425 Radiator Bushing: Automotive
Old May 6, 2015 | 08:31 PM
george__'s Avatar
That's ~$14 here in Canada
Old May 6, 2015 | 09:36 PM
bennuss's Avatar
thanks
as ana side really should make it another thread. I am getting a p0140 on my o2 every once in a awhile. It doesnt seem like the sensor is bad since i have monitored it just everyonce in a while it gets no activity. i changed it already twice. i think something is leaking onto the connector. Would it be power steering fluid ? (The high pressure power steering hose is new and isnt leaking.)
Old May 7, 2015 | 08:36 AM
DennisMik's Avatar
Originally Posted by Donkeypunch
They are $2.55 MSRP each at the dealer.
Nissan Part Number: 21506-51E00
MOUNTING-RUBBER,RADIATOR UPPER
FWIW, the lower ones are $9.98 MSRP each.
Nissan Part Number: 21507-51Y10
MOUNTING-RUBBER,RADIATOR LOWER
Old Feb 1, 2016 | 09:08 AM
link375's Avatar
if you need to replace the radiator / fans you can use this video as a guide.
Fans: http://amzn.to/1Sy4BoD
vingodine
45
May 21, 2016 12:46 PM
Samedi
Aug 12, 2015 01:54 AM
mls277
Aug 11, 2015 07:18 PM
kirkhilles
Aug 8, 2015 10:53 AM
