magnaflow Y-pipe difference
Old May 21, 2015 | 08:52 AM
KENBUILT79's Avatar
Hello all. Im looking at buying an 01 Maxima and he claims that the flexpipe is bad. I THINK that means that it needs a new Y-pipe? I found 2 from Magnaflow. Can anyone tell the difference? I did a search and i didn't find anything that made sense. Also the round part in the short tube (back cylinder back) is a Cat?
http://www.magnaflow.com/02catalytic...irectfit=24405
http://www.magnaflow.com/02catalytic...irectfit=49905
Old May 21, 2015 | 01:07 PM
a33_ridah's Avatar
If he said flexpipe...then its a smaller joining component between the exhaust pieces. Its the meshlike weaved pieces that are commonly called the flexpipe. An exhaust shop can weld a new flexpipe into an existing setup. A badly worn/torn flexpipe results in an exhaust leak....hope this helps.
Old May 21, 2015 | 01:21 PM
KENBUILT79's Avatar
Oh i understand what he meant. Im just not fimilar with the underside of a Max. The pics that i saw looked like the following. And if the car is in the Northeast then i assume that it will not come off the car without cutting/breaking bolts, so i figured that i would be ready to replace all the old stuff that was removed.
Quickywd01
Sep 21, 2016 09:36 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
