2003 maxima shuts off while driving
Old May 26, 2015 | 03:04 AM
holler's Avatar
I have replaced the fuel pump fuel filter the camshaft sensor 3 times the coolant temp sensor please help
Old May 31, 2015 | 04:56 PM
Daniel VQ30life's Avatar
do you have a SES light on? what code is it giving you
Old May 31, 2015 | 04:57 PM
Child_uv_KoRn's Avatar
Bad *** Newb
both cam sensors?
Old Feb 1, 2016 | 09:03 AM
link375's Avatar
have you checked the alternator? typically if your alternator is not working properly the car will shut off as it can't produce enough power to power everything in the car as well as the spark plugs.
If you end up having to replace your alternator you can use this as a guide.
Old Feb 1, 2016 | 09:41 AM
Prophecy99's Avatar
alternator, or CPS , sometimes aftermarket CPS give guys problems, could be that maybe try oem?
Old Feb 1, 2016 | 10:19 AM
maxiiiboy's Avatar
There are quite a few suspects here: Dirty/bad MAF, VIAS leaks/failure, bad Cam/Crank sensors, bad TPS.
Hondarydr
Dec 30, 2024 06:15 PM
twotonezed
Aug 16, 2015 08:10 PM
wingsfan24
Aug 15, 2015 07:35 PM
09maxshawn11
Aug 9, 2015 01:13 PM
yat70458
Aug 3, 2015 01:16 PM
