car randomly stalls
Old Jul 19, 2015 | 05:20 PM
Maxboy23's Avatar
car randomly stalls
Hi guys i drive a 02 maxima and ive been having some stalling problems with the car the check engine line is on and i got it checked and said it wad the camshaft position sensor bank 2. I got a new sensor which was not oem it was some kind of wells brand it wasnt a cheap brand though. So i put that it in and reset the code drive fine for about a week then the problem csme back on again it the code reader says its the same sensor? I guess this is a common problem with these cars. I hear you have to replace all 3 sensors both camshaft and crank to fix the the problem i dont know if this is true or not some help would be appreciated
Old Jul 19, 2015 | 06:27 PM
mclasser's Avatar
What was the code exactly?
Only use OEM sensors with these cars.
Old Jul 19, 2015 | 06:35 PM
Maxboy23's Avatar
I believe it was p0340 it was camshaft bank 2 and i didnt use oem it was some wells brand payed about 46$ for it looked exactly like it but i guess your right i hear oem is best for these parts
Old Jul 19, 2015 | 07:23 PM
nissanmax02's Avatar
car stalls
Hi! I've recently had the same problem with my car stalling. I try to give it gas and it just deccelerates. I have to pull over, cut it off, wait a few minutes and then crank it back up. It getting extremely frustrating!!! Can't even go out of town with it! However, she's been good up to this point. Bought cam and crankshaft sensors by Delphi. Haven't put them on yet because my mechanic says that's not the problem. Please help...need a resolution fast!!!
Old Jul 19, 2015 | 07:38 PM
Maxboy23's Avatar
Ok mine isnt that bad it just randomly stalls every now and then the mechanic is probably right seems likt something else i would put in those sensors first and if it still had the problem then get it diagnosed let me know if those sensors fix the problem because i hear only oem works
Old Jul 19, 2015 | 08:56 PM
maxiiiboy's Avatar
Well, for critical sensors, like this, you should use OEM. There is plenty of info on this subject on this forum. For your particular problem, read this thread: https://maxima.org/forums/5th-genera...ease-help.html
Old Jul 31, 2015 | 05:25 PM
car stalls
My car is still decelerating no matter how much gas I give it. Sooooo I put in the cam and crankshaft sensors...by Delphi. The fuel pump, outtake sensor/speed sensor, wiring harness, fuses, 02 sensors, computer and relays alllll checked out fine. Pleeeeease help!!!!! I'm getting soooo frustrated! Can't even ride out of town! Any suggestions!!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
