Master window switch compatibility - 5 and 5.5 gen
Old Jul 21, 2015 | 11:06 AM
Unclejunebug's Avatar
Awhile back I had pulled two Master window switches from 5th gens at a local junkyard and neither of them worked in my 5.5 GLE. I returned them as bad but now I'm curious if there's a compatibility issue between the two gens. The 5th gen switches I pulled did not have the AUTO feature on the passenger window switch but did on the driver's side (pulled from SE/GXE). My switch has AUTO on both.
There are a few more 5th gens I can pull from but I don't want to bother if they aren't compatible. Are there compatibility issues for this switch between the 5th and 5.5gen models?
Old Jul 21, 2015 | 01:46 PM
DennisMik's Avatar
The driver's side master window switch is different for every year of the 5th gen. You have to get the same exact one when you go to replace one.
You are right about the passenger door window auto up/down. The 5.0 didn't have it, it was a 5.5 feature. The 5.5 also has windows down from the key chain remote. The 5.0 doesn't have that, but I don't think this has anything to do with the window switch.
Old Jul 24, 2015 | 09:06 PM
Good to know, I appreciate the info. I grabbed a few more before I read this so rather than trying them I will just return them. Unfortunately a 5.5 gen in a junkyard around here is sort of like finding a unicorn. 5th gens are fairly common but the 5.5 gens, not so much.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
mpbclutch33
Aug 21, 2015 06:09 AM
MaxStock
Aug 14, 2015 10:01 PM
kjm900r
Aug 5, 2015 07:14 AM
