AT Check light
Old Jul 26, 2015 | 08:47 AM
Geno001's Avatar
AT Check light
Hello All;
03 maxima 120k miles auto trans. At startup every couple days I get the flashing AT Check light. Checked the fluid, its not burnt smelling or discolored. Trans shifts and functions normally. I am considering changing the fluid and filter. Looking for suggestions. I want to avoid the stealership as they want $25 just to replace a license plate light bulb.
Old Jul 26, 2015 | 02:41 PM
DennisMik's Avatar
Did you make sure that the AT oil is full as well?
Old Jul 26, 2015 | 02:48 PM
george__'s Avatar
Maybe the # of times flashing equals a code?
FSM have anything to say about it?
Old Jul 26, 2015 | 09:31 PM
DennisMik's Avatar
What you see at startup is just a flashing light to get your attention
There is a self diagnostic that you can run and then the AT Check light flashes in a coded pattern. Drive the car to bring the engine and transmission up to operating temperature. Make sure that the transmission oil is full.
Then start the self diagnostics.
See page # 53 in this link for the directions.
Old Jul 27, 2015 | 12:21 PM
Geno001's Avatar
I saw that diagnostic procedure. I will have to give that a try. Hopefully I'm coordinated enough to pull it off. Wet your left index finger and turn key on an off 7 times to the beat off we are the champions while standing on your left leg on a Thursday wearing a green shirt etc. I'll let you know what I find out.
tsi6001
Oct 3, 2022 10:23 PM
sake1bs
Sep 19, 2015 09:32 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
kjm900r
Aug 5, 2015 07:14 AM
