Remote window opening
Old Jan 26, 2002 | 11:12 PM
y sleep's Avatar
What is the simplest and/or best way to get the remotely open the car's windows for a 00 SE? I miss that feature from my 97 maxima and it is now available again with the 2002. Is there a particular aftermarket product that the members recommend?
y
Old Jan 26, 2002 | 11:16 PM
BigDogJonx's Avatar
Re: Remote window opening
y
The best way is to have it installed with your aftermarket alarm.
I dont think our stock remote has a 3rd channel for it to listen to if you say "held down the unlock" button.
But with an aftermarket alarm or even a simple keyless entry remote with an optional channel you can easily do it by buying a window roll down module. They cost about $25 to control 2windows.
Dixit
Old Jan 26, 2002 | 11:25 PM
y sleep's Avatar
Re: Re: Remote window opening
Thanks for the prompt answer. So I would have to put in an aftermarket alarm. I was concerned that would screw up the factory alarm. I'll ccheck around some local shops about the keyless entry devices.
Old Jan 26, 2002 | 11:32 PM
BigDogJonx's Avatar
Re: Re: Re: Remote window opening
It wont screw up the factory alarm, as long as you install the aftermarket alarm or have it installed correctly. Cause most advanced alarms have a wire that goes over and "tells" the factory alarm to disarm so you dont run into double arming issues.
Dixit
Old Jan 28, 2002 | 12:02 PM
y sleep's Avatar
Re: Re: Re: Re: Remote window opening
Thanks, I've just read and seen horror stories of aftermarket installations causing problems. I'll get something put in. Any recomm
endations on brands? I'll do a search.
Dixit
Old Jan 28, 2002 | 12:07 PM
BigDogJonx's Avatar
Re: Re: Re: Re: Re: Remote window opening
Well the best aftermarket alarms are the vipers and cliffords. Everyone can testify to that. And I believe Tweeter stores do a rack of installs on them. Dont know about Circuit City or BestBuy doing Viper or Clifford alarms.
Dixit
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
lrb6805
Sep 24, 2015 05:03 PM
