Install Rear Brake Pads
Old Jan 27, 2002 | 11:14 AM
maxdon
THIS MY FIRST ATTEMPT TO INSTALL REAR BRAKE PADS ON MY 2000 MAXIMA.CAN ANYONE TELL ME HOW TO GET THE CALIPER PISTON TO GO BACK INTO THE CALIPER? i KNOW THAT THE REAR PARKING BRAKE HAS SOME KIND OF AUTO SLACK ADJUSTER BUILT INTO IT, BUT I DONT KNOW THE CORRECT WAY TO GET THE CALIPER PISTON TO FULLY RETRACT BACK IN. ANY INFO YOU COULD WOULD BE APPRECIATED, AS THE CAR IS APART AS WE SPEAK.THANKS IN ADVANCE.
Old Jan 27, 2002 | 11:35 AM
maxdon
Re: Re: Install Rear Brake Pads
Originally posted by yo_its_ok
take needle nose pliers and use the thin end and start rotating in a clockwise direction, and it will compress.
This process will take patience, and you will probably bust you a knuckle or two trying.
Enjoy.
-Peace
Old Jan 28, 2002 | 09:04 PM
ABQMAX's Avatar
Needlenose pliers not strong enough, trust me I tried it only scored the face of the caliper. I finally succeded by using a pair of those big lock jaw pliers. i locked them around the outer edge of the caliper and turned it clockwise. BE CAREFUL not to grab the rubber boot. I know it is frustrating, but needlenose pliers or C-clamps do not work on the rear brake calipers
Old Jan 29, 2002 | 07:01 AM
DanNY's Avatar
Ad·min·is·tra·tor
of course having the tool to push the piston back is ohhh so much better
Old Jan 29, 2002 | 07:04 AM
ZIPPIN's Avatar
Mauja He Mauja
there is actually a tool available for that. i learned the hard way. but my dad made me the tool that sits perfectly on the piston,,,and rotates it with no problems
you can read thisrear brakes = pain in my rear
Old Jan 29, 2002 | 11:49 AM
dm7297's Avatar
you also have to line up the slots on the caliper with the little nipple that sticks out on the pad i had a b!tch of a time till i relized it was not lined up
Old Jan 29, 2002 | 11:56 AM
ZIPPIN's Avatar
Mauja He Mauja
he wrote LITTLE NIPPLE
Old Jan 29, 2002 | 01:38 PM
dm7297's Avatar
o yea gotta get the sex terms in while working on a car makes it more fun
rbuswell
Nov 17, 2016 04:54 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
