ABS Actuator replacement
Old Oct 12, 2015 | 07:34 AM
memphisballer's Avatar
I'm looking for the best way to bleed the brakes after I replace the Actuator for a '00 Infiniti I30.For anyone who has done it,Is there an easy way? It seems like it would be tricky.Just looking for a heads up before I get started.
Old Oct 12, 2015 | 08:54 AM
DennisMik's Avatar
There is a proper sequence for bleeding the brakes on a car with ABS. You start with the wheel that is the furthest from the ABS unit and work your way to the closest wheel.
That said, the easiest way is to get a pressurized bleeder. Without one, it is the old step on the brake pedal routine.
Old Oct 12, 2015 | 09:23 AM
Ok. Thanks for that bleed procedure.I wasn't aware of that sequence.
max ride 41
Oct 23, 2015 11:09 AM
Peace1967
Oct 11, 2015 02:35 AM
who4ever
Oct 9, 2015 05:50 PM
Frank Fontaine
Oct 5, 2015 09:49 AM
