Reverse Switch
Old Oct 20, 2015 | 08:49 PM
dangerzone's Avatar
Reverse Switch
Recently the reverse light, backup camera and sensor stopped working on my 2003 Nissan Maxima. After doing some research I've purchased this reverse switch on the picture below. My stereo unit detects when the shifter goes into reverse mode but the reverse light just doesn't come on, the backup camera and sensor are spliced to the reverse light. Hopefully replacing the reverse switch would fix that issue. Could someone please point me to the location of the switch? Preferably a picture of where it is located. Appreciate it
Old Oct 20, 2015 | 10:37 PM
DennisMik's Avatar
That looks like the reverse switch, also called the back-up light switch.
It is mounted in the top of the transmission, kind of in the center. Don't have a photo, sorry.
Old Oct 21, 2015 | 03:13 AM
dangerzone's Avatar
Can I access that switch from the hood or do I have to get to it under the car?
Old Oct 21, 2015 | 07:07 AM
Heel Til I Die's Avatar
I've never tried to access it from the hood. I guess it might be possible, but the easier way is to get under the car and remove the one bolt holding the switch in place. When you do, unless you have the car tilted, some fluid will come out when you remove the old switch. If you're due up for new fluid, it's probably a good time to drain it completely and refill it with some redline. If you recently changed it, then you can probably get by with only refilling the little amount that comes out.
Yours is a M/T, right?
Here's a pic from the FSM for the procedure on diagnosing it:
Old Oct 21, 2015 | 05:17 PM
dangerzone's Avatar
Great thanks!!
Old Oct 21, 2015 | 10:49 PM
Derrick2k2SE's Avatar
You'll have to access the switch from under the hood. remove the airbox and the switch is right under the bracket where the hard clutch line connects to the rubber line.
You'll need a 21mm deep well socket and you wont loose any fluid.
Here's a pic of my 02. It's hard to tell but I'm shooting from the radiator/bumper.
The second pic is for perspective.
Old Oct 23, 2015 | 09:24 PM
dangerzone's Avatar
Thank you so much man! The reverse switch fixed my reverse light issue. I've got another problem now, the rubber tube right above the switch came loose at the other end and I have no clue where its supposed to go. Does anyone know where the other end is supposed to connect to?
Old Oct 24, 2015 | 09:34 AM
No problem.
That tube is the vent for the transmission and doesn't go anywhere. Just bends over like a candy cane.
Jeffesernia11
Aug 23, 2015 06:09 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
09maxshawn11
Aug 9, 2015 01:13 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
