P0011 after clutch install
Old 11-10-2015, 03:16 PM
Buyers beware, local pick up recommended. Slow to ship out items already paid for.
cwfalconfootbal's Avatar
After replacing the clutch, flywheel, clutch fork and throw out bearing the car is throwing p0011 And seems to be in limp mode.
cwfalconfootbal is offline
Old 11-10-2015, 09:39 PM
Turbonut's Avatar
Who manufactured the flywheel, factory or aftermarket?
Flywheel installed incorrectly:
http://www.underhoodservice.com/tech...-installation/
Turbonut is offline
Old 11-11-2015, 12:06 AM
It's luk...so oem flywheel. I will show that to the mechanic that helped me. Any chance it could be the crankshaft position sensor?
Old 11-11-2015, 12:12 AM
Also, I thought that if it was installed wrong the car wouldn't run at all.
Old 11-11-2015, 04:22 AM
Turbonut's Avatar
I would think if it was the CPS/circuit it would throw a code e.g. P0335, or
if it's bad the car wouldn't run. Guess you could check the CPS resistance,
zero, short circuit, infinite, open and/or the output voltage when cranking, etc.
Hopefully some will chime in who's familiar with the M/T Maxima.
Turbonut is offline
Old 11-11-2015, 04:37 AM
It throws p0011. Car shifts beautiful tho now. I did find a recall for camshaft sensors and the crankshaft position sensor and I had to replace both camshaft sensors recently so might be the recall but...not sure if a 6speed crankshaft sensor is different and I can't bring the car to Nissan
Old 11-11-2015, 08:08 AM
DennisMik's Avatar
The code could be for either the crankshaft sensor or the bank 1 camshaft sensor. If the crankshaft sensor was damaged, I would think you would get the P0325 code and have problems starting the car.
But because you have had work done on the car, I would take the crankshaft sensor off and inspect the tip for damage. Then I would start focusing on the camshaft sensor, especially the wires that could have gotten damaged. Check the resistance of the sensor, it could have decided to fail. See page 172 in the EC section of the FSM.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EC.pdf
The crankshaft and camshaft sensors are the same for manual trans and auto trans cars.
DennisMik is offline
Old 11-11-2015, 08:23 AM
rbaksi's Avatar
Check the connections for the crankshaft sensor. Maybe you bumped something or nicked it while doing the install.
rbaksi is offline
Old 12-04-2016, 06:34 PM
pimpin02max's Avatar
Did you ever get this figured out OP? I know this thread is a little over a year old but I'm desperate. I'm literally in the EXACT same boat. I just put in a new flywheel, clutch, and pressure plate and I'm getting P0011 and P0021 codes and the car will barely run. After seeing the link someone posted I'm wondering if the flywheel is on wrong.
pimpin02max is offline
Old 12-04-2016, 07:26 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Unplug crank sensor and see if it's normal (most likely you're right).
Child_uv_KoRn is offline
Old 12-04-2016, 09:00 PM
I'll give that a shot first before I drop the transmission again. Good times lol. Hopefully I'll be able to knock the job out a lot quicker the second time around lol.
Old 12-05-2016, 05:46 AM
Yea. What happened was exactly what u said. My mechanic was my friend and a Honda tech. We did the job 3 times and only succeeded because I went to check my spare engine. The flywheel was still on it. I marked on the flywheel with marker where it lined up to the dowel pin. If the flywheel is in wrong the timing will be off.
Old 12-05-2016, 05:47 AM
Actually it's funny because I posted pics of my install on facebook last year and it came up on my year ago memories this morning
Old 12-05-2016, 01:33 PM
Thank you very much for the reply! I'm going to take it all apart again this weekend and get the flywheel lined up properly.
Old 12-13-2016, 07:06 PM
Just wanted to share an update on my experience.
I took the transmission off again and uninstalled the clutch/pressure plate and the flywheel. Sure enough, the flywheel wasn't clocked correctly. There's actually a few quick and easy ways to 100% ensure that it's on correctly. For one, there is only a single hole in the flywheel that has a little square in it, this is the hole that goes on the dowel pin that sticks out of the crank. Second, there is also a gap in the timing ring which is what the crankshaft position sensor is looking for, you can also line that up to make sure it's correct (it's right above the aforementioned hole with the square). There is also an arrow on the outward facing part of the flywheel that will point to the hole with the square in it.
I can't believe I missed all of that the first time, what's even more weird is that in 2011 I swapped the engine on it and transferred the flywheel over to the new engine and I can't seem to remember lining anything up...maybe I just got super lucky lol.
But now engine is running great...unfortunately it is very hard to get into gear. I've already swapped the slave cylinder, I guess next I'm going to swap the master cylinder and put on a one piece braided clutch line as that factory setup is an absolute mess.
rbarnes
12-28-2015 04:32 AM
Mike_Max1775
11-10-2015 09:06 PM
njpunkmusic
11-10-2015 09:29 AM
Maxima_Joe
11-06-2015 02:41 PM
Quick Reply: P0011 after clutch install
