gear selector swap
Old Nov 11, 2015 | 08:51 AM
2kmaximel's Avatar
gear selector swap
has anyone swapped out the older looking gear selector from a 2k with one from a 02-03? since trying to find an AE shift **** is almost impossible maybe swapping to the newer gear selector is easier. any input would be greatly appreciated. thanks.
if you have an AE auto shift **** for sale please let me know.
Old Nov 11, 2015 | 09:05 AM
Chris Gregg's Avatar
Get Off My Lawn
There are some mechanical differences I'm not sure you can overcome. First, as best I can recall, the throw of the shifter is longer for the 5.5 version. It also does not follow a linear path from P to 1. I'm trying remember if the 5g has overdrive on dash or shifter - in any case, OD is built into the shift mechanism for the 5.5 NOT a button. Also, the shaft on the 5.5 is solid and it uses a manual shift ****.
Fitment is the easy part. Getting it to work properly is going to be the challenge. Though, why not install a non-AE 5g shift mechanism?
pieterm
23
Dec 15, 2015 01:52 PM
Icykilla1
Oct 30, 2015 08:03 PM
