Code P507
Old Nov 21, 2015 | 01:39 PM
indie007's Avatar
Code P507
Need Help
I have 03 maxima and got P507. Some says got issue with IAC or while other say replace whole Throttle Body. Can someone suggest what is required to get it fixed?
Old Nov 21, 2015 | 02:56 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by indie007
Need Help
relearn the idle
There's lots of threads on this.
Old Nov 22, 2015 | 02:22 PM
indie007's Avatar
Thanks, for idle relearn, I guess, dealership is my best bet
Old Nov 22, 2015 | 02:31 PM
Mattx's Avatar
follow the steps on the relearn and save the $$$$$
Old Nov 23, 2015 | 04:35 PM
indie007's Avatar
I tried it multiple times and brought the rpm to 800. Is that normal or needs to be lower?
Old Nov 24, 2015 | 07:57 AM
user 11122324's Avatar
it should be lower. For AT the idle should be at 700-750 rpms and for MT it should idle around 625-675. If it is any higher than those parameters then you need to do the idle relearn again. On one of the idle relearn write ups the author mentioned that he did the relearn manually several times but he had to leave the negative battery cable unplugged overnight for it to work. Just a thought.
here is the link to the write up i am referring to
https://maxima.org/forums/5th-genera...00-2001-a.html
Colossus
Sep 9, 2015 05:46 AM
lowpost99
Sep 8, 2015 05:06 AM
boomerbrian
Sep 2, 2015 03:46 PM
paulpearl
Sep 2, 2015 07:50 AM
