Can I put my 2003 Toyota Camry xle HU and speakers in my 2003 Nissan Maxima?
Old Nov 28, 2015 | 09:30 AM
PuddinTane's Avatar
Like I have seen all over this forum, people are having problems with the cd player only having sound coming from the right side; well so am I. I just got this 2003 Maxima 6 months ago after my 2003 Camry got written off after an accident resulting in the frame being bent beyond logical repair. However, the sound system and HU still work perfectly and personally I liked it a lot better. Is it possible to put the HU and speakers from my 2003 Camry xle into my 2003 Maxima? I really don't like the bose stock system in it and the right side problem is infuriating. FYI I don't know much about cars, hence why I am asking on here. Thanks
Old Nov 28, 2015 | 10:58 AM
sanford7575's Avatar
Bad news... Since you have the bose system, it is not compatible with other speakers due to different resistance (ohm) values. Bose use 1 ohm speakers, while most others are 4 ohm. Secondly, replacing the speakers from the affected side most likely wouldn't solve your problem anyway, as the sound from one side issue is most likely a Bose head unit problem, not a speaker problem. Please search the multiple threads here about bose issues, but the best option is to rip and replace the Bose head unit and speakers. It's a little more upfront cost, but well worth it in the end. I have an '02 and '03 maxima, and I replaced the entire system in both cars , and am much happier. Now I have double din dvd players with amplifiers and pioneer speakers all the way around. I even added a small sub box in the trunk for great sounding bass as well. My advice is to replace the entire sound system!
Old Nov 28, 2015 | 01:00 PM
DennisMik's Avatar
Sanford gave you the bottom line and I will second that, at least partially. I also think you have come to that conclusion.
I was checking into the "Toyota-radio-in-a-Maxima" maybe a year ago and what I found out was that the Toyota head unit was physically larger than the head units Nissan used and would not fit in the Maxima opening. I don't remember what year and model Toyota the radio came out of, but chances are they are all the same size.
Earlier this year I replaced my Bose head unit with a Kenwood. I bought the radio, line adaptor, wiring adaptor, antenna adapter, trim adapter - everything for just under $160. I did use the Bose speakers because there wasn't anything wrong with them.
Old Nov 29, 2015 | 09:25 AM
Cotozic's Avatar
I mean, regardless of what you do, make sure you take off your door panels and check the condition of the speakers. The ones that aren't working may just have corroded terminals that are preventing them from working, or even perhaps a loose wire. I had this problem, non-bose, when I switched from factory sound, and corroded terminals were the cause of all my problems.
Max139617
44
Apr 27, 2016 11:43 PM
~V~max
29
Dec 5, 2015 11:30 AM
JM AUTO RACING
Oct 26, 2015 06:30 AM
TriniMax3.0
Oct 22, 2015 11:19 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
