Can you use automatic transmission fluid on a manual tranny?
Old Jan 17, 2016 | 08:24 PM
Dayan27's Avatar
Hello i have a 2001 manual maxima and i just did a clutch replacement and i have to put some transmission fluid but i wonder if i can use automatic transmission fluid?
Old Jan 17, 2016 | 08:59 PM
Fakie J Farkerton's Avatar
That's a big NO.
GL-4 only.
Old Jan 18, 2016 | 04:39 AM
Turbonut's Avatar
Many cars from the factory use ATF in a manual, and many use ATF, especially in cold weather applications, but I wouldn't recommend the use long term.
Old Jan 18, 2016 | 04:55 AM
Derrick2k2SE's Avatar
I wouldn't put anything in there but GL-4 MTF. Not even for a minute. The syncros are designed to need a specific amount of lubrication AND friction to function properly.
Old Jan 18, 2016 | 07:18 AM
Turbonut's Avatar
Back in '88 when I purchased our TII new, it was a bear shifting when cold (GL4) so Mazda, corp, used ATF in the cold weather areas, no problems. Traded it in on a new '89 TII, nothing but RedLine. Just an FYI-still have the car.
Old Jan 18, 2016 | 12:26 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Cst in the 7s isn't good when we're using redline in the 14s (at 100C)...
Other transmissions probably call for oils of 8.x cst, so ATF being much thinner when cold would be a match for cold climate viscosity wise. But, that's still absurd. I would just use 0w/5w30/40.
Old Jan 18, 2016 | 12:43 PM
Turbonut's Avatar
I agree. In fact, in the '89, both the trans and diff fluids were changed to RedLine at 3k miles.
spidgeon
Nov 26, 2020 05:04 PM
Lord Vader Vandross
Dec 9, 2015 12:44 PM
Dab
Oct 29, 2015 06:57 PM
maxima297
18
Oct 27, 2015 10:29 PM
maxima_addict
Oct 26, 2015 01:27 PM
