Rough idle(every 30 seconds)
Old Jan 28, 2016 | 04:05 PM
Chuckstone's Avatar
My 2000 Maxima idles rough for exactly 30 seconds then idles smooth for 30 seconds. I've timed it and its exact. It sometimes dies during the rough idle period. Any ideas as to the problem? Engine light has not come on and no codes.
Old Jan 28, 2016 | 06:28 PM
maxiiiboy's Avatar
Interesting. If it was my car, I would check the battery voltage and see if it also goes up/down in sync with the car irregular idle. Of course, the next question is "What is the cause and what is the effect?", but checking the voltage is a place to start.
Old Jan 28, 2016 | 07:00 PM
mclasser's Avatar
Do the RPM's jump up and down when this happens? Could be the IACV.
Old Jan 29, 2016 | 07:27 AM
Chuckstone's Avatar
I already replaced the IACV and TPS. I'll check the voltage and see if the irregularity is in sync. Thank you for the suggestion.
If the car is not warmed up the engine dies when put into gear.
Old Jan 29, 2016 | 10:45 AM
VQ35maxima=Beast's Avatar
I was thinking MAF, but i dont know why it would happen every 30 seconds.
Old Jan 29, 2016 | 11:01 AM
Chris Gregg's Avatar
Get Off My Lawn
Use a code reader and check live data. Look specifically at the O2 sensors and see if their readings consistently change with the idle.
I'm going to assume you've got a vacuum leak.
Old Jan 29, 2016 | 12:57 PM
Chuckstone's Avatar
I do hear a slight whistle in the engine. I thought that it being exactly 30 seconds that it switches from smooth to rough idle, might help pinpoint the problem.
Old Oct 18, 2021 | 01:59 PM
Jarsituation's Avatar
My daughter's car is doing the exact same thing did you ever figure out what it was?
Old Oct 18, 2021 | 02:11 PM
Ohktya's Avatar
Crazy thing is iVe got the same issue right now and still can’t solve it, been ongoing for like 2 months now
Old Oct 18, 2021 | 02:14 PM
we must get to the bottom of this! lol
Old Oct 18, 2021 | 04:22 PM
RA030726's Avatar
I'm nutty for Nissans
Is the air conditioner compressor turning on and off?
Old Oct 18, 2021 | 04:35 PM
TallTom's Avatar
That was the 1st thing I thought of when reading all of this. I think low coolant can trigger the compressor to go on and off.
Old Oct 19, 2021 | 09:24 AM
RockyTop2k's Avatar
Hitachi IACV
My 2000 was doing the same thing but only when is was below 40°F. I replaced the IACV with a cheap 1 from Amazon. Actually made it worse. Bought the Hitachi IACV & it fixed it.
Old Oct 19, 2021 | 10:37 AM
AC is off
However, I'm getting a code for random multiple cylinder misfires. Prior to this I had an ECM failure. The ECM was sent out and repaired and I also replaced all 6 ignition coils and spark plugs. Obviously to get to the back three cylinders the intake had to come off so even though I'm pretty sure everything got hooked back up I'm hoping a vacuum line got left off somewhere. Wishful thinking of course though lol
Maxima_Mars
Apr 4, 2015 10:26 AM
klemenz
May 21, 2013 05:41 PM
monty31
Nov 11, 2006 11:07 AM
RockfordMax
Jul 8, 2006 02:21 PM
konak85
Mar 25, 2006 08:07 AM
