Carrier Bearing Bolts in CV Axle Replacement (passenger side)
Old Mar 9, 2016 | 10:53 AM
willco's Avatar
I am replacing the front passenger side CV Axle on my 2003 Maxima. I have the axle out of the wheel assembly and have moved up to the carrier bearing where the axle is braced (between the wheel and the automatic transmission).
I cannot figure out how to get a wrench with leverage on the top two bolts. The bottom one I can probably get with enough tenacity, but the top two are monsters. I have tried a two foot extension, but I don't seem to have the clearance to get it through.
What do people use to get these bolts off?
Old Mar 9, 2016 | 11:00 AM
Child_uv_KoRn's Avatar
Bad *** Newb
1/4 ratchet with swivel and extension (I don't remember the combos needed). Even with my jumbo hands it's not a huge deal. You just have to be steady, so it doesn't slip off.
SOAK the whole thing in lube. I've had to PUNCH those suckers out b/c they're oxidized in there so bad. And don't forget to grease the **** out of it for reinstallation.
Old Mar 9, 2016 | 02:54 PM
FanaticMadMax's Avatar
Been there, done that. I used a combo wrench racheting, I think it's a 13mm bolt, not sure, it takes some time and patient to get it off since the bolt is very long.
Old Mar 9, 2016 | 03:44 PM
nestorlugo's Avatar
I used a combo too ,small 4" 12mm wrench to brake them loose and a ratcheting wrench to get them all the way out
Old Mar 9, 2016 | 04:07 PM
losifanatic's Avatar
My bolts cane out easy. All the threaded parts on the cv are broken and my bolts are gone. Picked up a new cv yesterday. Picked up a bunch of bolts and will see what fits. Don't know how they broke?????
I used a wrench and it took forever on my 2k maxima
Old Mar 10, 2016 | 07:56 AM
DennisMik's Avatar
I used a 12 mm socket on a 12 inch long extension connected to a u-joint on a 6 inch extension. Down here in the south, we don't have the road salt corrosion problem and the bolts came out easily.
Old Mar 10, 2016 | 09:32 AM
Bad *** Newb
To clarify, the bolts are easy enough, but the axle can be cemented in there (car was not even rusty).
I literally used a chisel and hammer and pounded the **** out of it for a few mins.
Old Mar 13, 2016 | 08:42 PM
Requin6's Avatar
This is also the method I use to remove the carrier bolts. Run the 12in. extension through the engine cradle and the 6in to get access to put a ratchet on.
I have had to use an air hammer/chisel to remove the axle from the carrier bearing before. No fun.
Old May 4, 2016 | 11:16 AM
maximatech12's Avatar
slip the axle nut socket over the end of the combo and break it loose.
Old May 4, 2016 | 01:11 PM
AT978's Avatar
The shortest open wrench you have, nimble hands, patience as you turn the bolt 1/24 turn at a time
Old May 4, 2016 | 02:22 PM
Turbonut's Avatar
I leave the brace in place. Just use heat and the axle/bearing will come out.
Old May 4, 2016 | 05:58 PM
Smack a chisel in between after you get the bolts out to separate the bearing from the support.
Old May 4, 2016 | 06:02 PM
cornholio's Avatar
what do you gain by bumping a 2 month old thread and repeating info that has already been stated?
Old May 4, 2016 | 06:10 PM
for the archives. Three years from now a 2003 max owner may want a good way to break those PITN bolts loose without removing the exhaust tube.
Old May 4, 2016 | 06:12 PM
cornholio's Avatar
good call, because the other posts saying the same thing will be deleted in 3 years
Maxboy23
May 3, 2016 07:45 PM
ColdCananda
Apr 15, 2016 01:13 AM
tmorales509
Feb 29, 2016 05:08 PM
hooloovoo
Feb 24, 2016 08:30 PM
ColdCananda
Feb 16, 2016 03:50 PM
