2001 maxima shutting off
Old Mar 16, 2016 | 12:27 PM
Tru Faith's Avatar
Hi guys..I recently bought an 2001 maxima and drove home about 30 miles with no issue... Filled up the tank tank with 89 the next day because it was almost on E then parked it... A day after I'm driving to work and it kept on shutting off.. I got it to turn back on by constantly pressing the gas and revving the engine.. Then it would shut off after I release the gas... It only stays on if I'm revving the engine, once I let go it would shut off and the check engine light or any other light did not come on.. Any reason why you guys think this happens?
Old Mar 16, 2016 | 12:43 PM
maxiiiboy's Avatar
Two types of failures have these symptoms: MAF and IACV.
Try disconnecting your MAF (just disconnect the electrical connector). If the car starts and idles, although poorly, with the MAF disconnected, you need to clean or replace your MAF. If not, it's time to check out your IACV. IACV failures are usually associated with P0505 code but sometimes the CEL/code comes on some time after the failure occurs. In either case, be aware that the failure of the IACV often results in ECU damage; this note https://drive.google.com/file/d/0B6O...psNVBqUVk/view explains.
Old Mar 16, 2016 | 03:00 PM
Child_uv_KoRn's Avatar
Bad *** Newb
He might get lucky if he does the coolant bypass and cleans the IACV.
Old Mar 27, 2016 | 06:15 PM
beechmon's Avatar
What do you mean by this?
Old Mar 28, 2016 | 04:25 AM
5thgendriver's Avatar
https://maxima.org/forums/5th-genera...nt-bypass.html
Old Mar 28, 2016 | 04:43 AM
Bad *** Newb
Do the bypass mod, so if the IACV/O-ring is going bad, then it won't fry the ECU. Perhaps the IACV is just clogged up, so if it's cleaned, then maybe that will fix the problem. It's the 1st thing to do before throwing parts at it.
Old Mar 28, 2016 | 07:57 PM
Donkeypunch's Avatar
idk if I posted this before but my idle valve went bad because the o-ring failed.
Coolant gets in there and fries it. That's why I think o-rings are bull**** for something like that
but that's nissan for you.
Malibu Jim
Feb 4, 2016 09:43 AM
ANDY.VIP
Jan 27, 2016 09:08 AM
a1gio2
Jan 17, 2016 05:49 AM
BobMax
Jan 15, 2016 06:51 AM
