Car dies rite after start
Old Mar 28, 2016 | 04:58 PM
JDM_A33's Avatar
I have a 2000 5 speed maxima with intake and fatback exhaust both eBay parts nothing fancy. Last two times it has rained all day the car runs for a while and then after it is off for a little while. I will try and start it and car will die after a few seconds and just dies faster if I press the gas. Any ideas please help
Old Mar 28, 2016 | 06:18 PM
Sounds like your MAF is toast. Disconnect MAF and see if car will start and idle (don't touch the gas pedal). Report back.
Old Mar 28, 2016 | 08:23 PM
maxiiiboy's Avatar
Originally Posted by the wizard
sounds like your maf is toast. Disconnect maf and see if car will start and idle (don't touch the gas pedal). Report back.
^^^ +1 !
Old Mar 29, 2016 | 04:44 PM
JDM_A33's Avatar
Just tried that still same issue
Old Mar 29, 2016 | 04:59 PM
Child_uv_KoRn's Avatar
Bad *** Newb
FWIW, I've never had much luck with the car running without maf plugged in.
I'd definitely snag some from the junkyard and see.
Old Apr 3, 2016 | 09:57 AM
JDM_A33's Avatar
Just got a different maf sensor from a running car and installed it and still same issue. Any other ideas ?? HELP PLEASE
Old Apr 3, 2016 | 10:26 AM
Bad *** Newb
Time to start swapping sensors, I guess. Swap both crank sensors with the other car.
I wouldn't think it would run for a while and restart at all if fuel was an issue. Very odd that it dies faster when throttled up.
Old Apr 3, 2016 | 11:18 AM
JDM_A33's Avatar
The front one by the mount and the other one by the pulley??
Old Apr 3, 2016 | 02:33 PM
Mattx's Avatar
Check the intake system for any cracks or leaks. That would be the first place I would go after maf
Also do the pedal dance and reset everything.
phoboi2006
Jul 23, 2016 08:45 PM
maxima297
Jan 22, 2016 03:27 PM
Anovice
Jan 20, 2016 04:38 AM
Jamaalrly
Jan 10, 2016 01:19 PM
