spark plug change
Old Apr 11, 2016 | 02:06 PM
sebastian2041's Avatar
spark plug change
Will be doing spark plug change soon I am ordering the ngk LFR5AIX-11, my mechanic told me to bu the boot for them too not the coils tho. Any suggestions on best boot brand to buy?
Old Apr 11, 2016 | 02:36 PM
Donkeypunch's Avatar
I think you miss understood him because there's zero need to put a new boot on a coil on plug.
Old Apr 11, 2016 | 04:13 PM
MadMax SE's Avatar
Not always true, my old ones on my acuras coils were dry rotted and kept sticking to the plug when i would pull the coils out (was so annoyong!) i had to use long needle noses to get it out.
Old Apr 11, 2016 | 04:24 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Grease...
Old Apr 11, 2016 | 04:37 PM
MadMax SE's Avatar
I always used di-electric grease but the boots no longer had elasticity where the boot hugged the coil. I believe they were stock coils and they that 187xxx on them
Old Apr 12, 2016 | 06:02 AM
Derrick2k2SE's Avatar
I've seen that before but never on a Maxima. These boots are put together really well. Anything's possible but it's not something I would prepare for on these cars. Just this year I did plugs on both my cars. One at 200k, the other at 300k (240k on the coils) and they looked brand new.
sebastian2041, If you're worried about it just pull one of the front coils and see what it looks like. There's nothing to it. Remove the cover and it's one 10mm bolt.
Old Apr 12, 2016 | 07:54 PM
Will talk to my mechanic and will che k spark plugs.. He didnt say anything about ignition coils just boot and spark plugs i wil talk to him to see what he says
Old Apr 12, 2016 | 08:11 PM
nestorlugo's Avatar
Just ask him to show you what he's talking about so you can take it with you to the parts store
maximatech12's Avatar
I saw boots for sale when I priced spark plugs too with NGK. What's involved in replacing the boots? My biggest concern is making sure the rocker arm covers are sealed and that the O-ring seals around the spark plugs are sealed. I'd make sure there's no oil leaking into where the spark plugs are.
Old Apr 12, 2016 | 08:32 PM
Well iknow what spark plugs he said boot but i like to buy online straight from retailer since its a littlecheaperjust didmt know which brand is thr best or good for the boots
Also read on the forums to replace gaskets while im at it( don't remember which ones) but should i replace them if so which ones and which brand
Old Apr 13, 2016 | 07:10 AM
The boots are part of the coils. When you pull the coil, the boot is the part that slips over the end of the spark plug.
I believe you're more likely to damage the coils by screwing with them than you are to see any need for new boots.
Replacing the valve cover gaskets is a different job but it's a good time to do it while you're already in there. You'll have to buy the tube seals separately from the VC gaskets but they are available.
Old Apr 13, 2016 | 03:59 PM
Good point.
Old Apr 13, 2016 | 05:41 PM
cornholio's Avatar
the felpro kit comes with tube seals
Old Apr 13, 2016 | 05:55 PM
Good deal. That sounds like the kit to go with. I've had good luck with Felpro too.
Old Apr 14, 2016 | 10:34 AM
mclasser's Avatar
Make sure to take your time during this job. Chances are some bolts and hoses will break in the process due to age so be prepared.
Old Apr 14, 2016 | 11:45 AM
FanaticMadMax's Avatar
Yes, boot should be replace, since they are made of rubber material, they do tend to lose elasticity and tear easily, I had to replace the boots when one of the boot got separated from the coil when I was trying to change the plug at 80k and when I tried to get the boot out, it got ripped so I ended up replacing all the boots since it would make sense that they are all the same age.
Old Apr 14, 2016 | 01:29 PM
which brand of boots did you use?
Old Apr 14, 2016 | 01:33 PM
It's a 5th Generation. How many miles? If it's more like 200xxx miles, you would more likely want to double check the entire fuel delivery system and check the fuel hoses from the tank pipe to the fuel injectors You would probably want to re-seal the fuel injectors too. They could begin leaking too when you shut the car off. It will leave your oil smelling like fuel.
Old Apr 14, 2016 | 02:16 PM
Nope it only had 110k on it just want to know what to do while im swtiching the spark plugs just to not have to take everything again very soon
Brandon Fagan
Nov 2, 2016 11:42 AM
inspiredbykev
Jul 13, 2016 05:29 PM
nkf
Apr 6, 2016 07:17 PM
rsinob
Mar 30, 2016 03:04 PM
